I've posted before that right now I have an 85 6.9 with a snapped head bolt stuck in it. There are a few things I'm worried about aside from the bolt not coming out but thats a different story I don't want to get into that, I'll ask about that when/if the time comes.
But for now I'm weighing my options if the bolt doesn't come out or something along those lines, so i'm look at engines on craigs and ebay to swap in and just part the old engine. So already long story short, one i'm looking at is an 83 6.9 and I think I remember hearing there is something they changed in 84 or 85 that improved the engine.
Am I making this up? or was there a change. And if there was what is the difference and is it something I could take off of or swap out from my 85.
Thanks in advance for any info and sorry for being so long winded.
Early 6.9's (83-mid 85) had a thinner block, and tend to crack at the block heater when used.
So long you don't use the block heater you'll be fine.
Also it be best to make manual glow plugs on earlier 6.9's as there glow plug systems like to fail and turn the glow plugs on and keep 'em on untill they all burn.
And last but not least, rocker arms are weaker on 6.9's 1983-1986, and to make it bullet proof, replace with 87 6.9 rockers arms or any 7.3 IDI rocker arms. It is a direct bolt in swap.
Edit:
Cut the block heater cord, update/manual glow plugs, and replace rocker arms and you got a bullet proof 83 6.9L
ok well i live in new england so i might be needing a block heater
so is it an engine i should stay away from.
Also is there a code on the door or something that will tell me if my current 85 is a thinner block one or not. because i have a block heater and if i end up keeping i sure don't want to crack the block.
If it is an early 85 what would i do in the winter if the block heater is a bad idea?
and i already have 7.3 rocker arms i was gonna put on the 85
I think it was discussed on here about using an inline hose heater instead of the block heater on the earlier engines. There were some differences around the frost plug hole where the block heater is mounted, and also seems to me that there was another difference around the oil dipstick mounting hole....
