Radiator Problems
Old Oct 22, 2010 | 11:46 PM
Austy's Avatar
Austy
Question Radiator Problems
My radiator keeps filling up my overflow tank and when it's running and then when it's off it eventually pulls it all back in. Any thoughts?
Old Oct 23, 2010 | 03:59 AM
jowilker's Avatar
jowilker
Perfectly normal. 4.5 gallons of cool fluid expands when heated and contracts when cooled.
John
Old Oct 23, 2010 | 09:21 AM
Victor L's Avatar
Victor L
Sounds normal as long as at isn't over heating. My truck does not have an over flow tank, and it automatically lowers the level to about a quart and a half low.
A bad radiator cap will cause a vehicle to over heat.
Old Oct 23, 2010 | 11:15 AM
Austy's Avatar
Austy
I got my radiator down to half a tank of antifreeze and it still filled up my 1 gallon jug and overflowed out of that.
Old Oct 23, 2010 | 11:29 AM
BobbyFord's Avatar
BobbyFord
Assuming you aren't overheating, have your cap pressure tested and/or replace it.
Old Oct 23, 2010 | 11:31 AM
Victor L's Avatar
Victor L
What do you mean by that? Is it just puking all the coolant out? If so will it do that on a cold engine? Is it over heating? Does it have to get hot before it overflows?
Old Oct 23, 2010 | 01:50 PM
jowilker's Avatar
jowilker
Now you have changed the dynamic, you didn't say it was doing that from half full down.
As suggested first check or replace the cap. Sounds like you may have some other issues if the cap doesn't fix it.
The fins on the pump could be rotted off, the complete system could need flushing professionally.
Do the cap thing and post back.
John
Old Oct 23, 2010 | 08:23 PM
Austy's Avatar
Austy
I just had it flushed in August. And it does it before the temp gauge even gets to warm. I'll get myself a new cap from lmc and let ya'll know.
Jon
Old Oct 23, 2010 | 08:25 PM
Austy's Avatar
Austy
Oh, and now we all know the joker's name...bobby...
Old Oct 23, 2010 | 10:34 PM
Austy's Avatar
Austy
Ok New symptom. I put the new cap on and it still started filling. But this time I stayed in the truck and watched the jug filling from inside and also monitored the temp gauge. Well as the jug filled the temp went up, but all of the sudden the gauge dropped back to a normal level and like almost instantly it drank all the antifreeze back up.
Old Oct 24, 2010 | 09:04 AM
BobbyFord's Avatar
BobbyFord
You witnessed the instant that the thermostat opened up.
Old Oct 24, 2010 | 02:37 PM
Austy's Avatar
Austy
So why isn't it opening when it should?
Old Oct 24, 2010 | 05:31 PM
BobbyFord's Avatar
BobbyFord
It's normal for the radiator cap to allow coolant out the overflow when the coolant thermally expands. If you didn't have the overflow container the radiator would only puke out so much and then your coolant level inside the radiator would remain an inch or two below the radiator opening when cold but since you have the overflow container the radiator will expel the expanded liquid and draw it back in as the engine cools.
Old Oct 24, 2010 | 05:34 PM
Austy's Avatar
Austy
But it didn't do that for the whole last year that I've owned it...
Old Oct 24, 2010 | 05:59 PM
BobbyFord's Avatar
BobbyFord
If you have a temp probe or gauge you can put it into the radiator opening and see at what temp the thermostat opens (just make sure you drain some coolant out of the radiator first to allow for expansion with the cap off). Or you can remove the thermostat, put it in a pan of water on the stove and boil it and measure at what temp the t-stat opens.
Pridnjoy
Sep 17, 2021 08:23 AM
BigBlueCat
May 25, 2014 02:16 PM
Aggie.2012
2004 - 2008 F150
Nov 1, 2011 06:57 PM
429CJ-3X2
Aerostar
Feb 13, 2011 09:57 PM
b4000er
1983 - 2012 Ranger & B-Series
17
Mar 3, 2005 02:06 AM
