OT New shop
Before I poured the floor I sunk tie downs. I used 20" truck wheels and welded a 10 inch diameter pipe to the centers. About 4 inched from the top of the pipe I cut a hole in the pipe and inserted a piece of small I beam through the pipe.
This gave me a place to wrap a chain around the I beam inside the pipe. I sunk the wheel flat down and poured the floor. The pipe was about 10 inches long. This let the large truck wheel be under about 10 or 12 inches of concrete and the top of the pipe level with the surface of the floor. I have a flat plate that fits over the pipe and it is level with the floor.
I very often uncover the pipe and chain to the I beam if I need to hold something or bend something heavy. I have 9 under my floor in a 3 foot square pattern.
I do heavy body work and often need to bend frames or body parts. I do have a frame machine but is sometimes much easier to just chain the vehicle to the floor and put a floor jack under the frame to remove a small bend or twist.
I also have a trolley beam and trolley mounted running across the shop and often use it removing engines and moving them across the shop, or simply removing something heavy from the back of the truck. It is faster and easier than using a cherry picker and requires no floor space.
My shop is 50X70 and not large enough. I didn't use the higher ceiling and have my lift outside.
The lower ceiling helps heating and cooling cost.
Good luck what ever you decide to build.
Larry
Sam
Since my 4' high block foundation is 3' into the hillside at the rear I had a roll on elastic waterproofing membrane added to the outside of the block where it is below grade protected by 3/4" foam board and a french drain all the way around to keep everything dry.
have power, water, sink drain and center drains run. have to squeeze in another spare conduit, pour monday.
Sam
a 36 in man door-if you can put in a toilet,also a slop sink,i dont have
any heat in my garage but i do have 8 celing fans (all given to me free)
i have 8 2tube 4ft flourescent lights 2work benches about 30in wide x10ft long
when i put my2x12 together to make my work bench i put Liquid nails in
between each board then i put a 1x3 against the wall & the bench ,used
Liquid nails again,then i put varnish over all of the wood.The liquid nails
stops all the little screws & other things from falling & getting stuck between the boards
My compressor is in the corner by the overhead doors,i ran tubing all the way
around the building having outlets for my compressor & electrical outlets.
I hope that this helps you out a little
One more suggestion for the pour is chain pots. They are nice for doing major bodywork..... I'll agree on that. My next garage will have them.
If your garage doesn't have high ceilings you might consider a mid rise lift, a portable drive on lift that uses and electric scissors mechanism to lift a max of 4'. Even if you can't stand under a vehicle that high it still is very convenient to be able to use a rolling stool and work sitting down. Even if you can only lift 2" high, it is still easier to work off a creeper at that height underneath without banging your head all the time and makes doing the lower half the bodywork a pleasure rather than a pain. If your budget is still too strained, get yourself 4 of the wheeled dollies that go under the tires. They still give you some extra height and the ability to move the vehicle around the shop, even sideways.
Sam
Great
I'm glad you got that done. I think you will use it a lot. If possible you might try to get another one in place.because if you realy need to pull something with only one it will still try to swivel around so two would work much better.
Larry
I like this type since it leaves the center clear.
FREE SHIPPING Bend Pak Clear Center Low Rise Vehicle Lift 6000-Lb. Capacity, Model# P-6 | Scissor Lifts | Northern Tool + Equipment
