temp sending unit
Old Oct 30, 2010 | 08:15 AM
skipr's Avatar
skipr
temp sending unit
I need help finding a temp sending unit to work with the orignal guage conveter to 12 volt. the 1 on my 300 6 is for a light and after adaping the 1 off my flat 6 it moves but shows hot after 5 min motor is running at 190. any help is aprecatied
Old Oct 30, 2010 | 10:28 AM
BlueOvalRage's Avatar
BlueOvalRage
The original sending unit should work fine IF you install a voltage reducer to feed the guage. Are you using a voltage reducer to cut the guage supply voltage back to 6 volts?
Old Oct 30, 2010 | 01:42 PM
skipr's Avatar
skipr
the guage does nothing with original off the 300 the 1 off the flathead goes to cold when started but moves right up to h after 5 min
Old Oct 30, 2010 | 04:12 PM
Julies Cool F1's Avatar
Julies Cool F1
So let me get this right. You have a 300 cu/in engine in your Bonus Built. It's converted to 12 volt, and you have eventually reinstalled the temp sending unit from the 226 flathead 6 onto the 300 right?
That's the right set up. But you need to add voltage reducers to all your original electric gauges (or one for all of them if you prefere that type) to compensate for the voltage increase.
WRT sending units, you have to use the one that has the proper resistance scale for the gauge - IOW you need to use the one supplied with that gauge.
Other can be installed or adapted but there's no reason at this point to confuse you with that process at this point.
Here's a link on installing the individual voltage reducers it's hsown on a 51/52 instrument panel, but it's exactly the same same process.
https://www.ford-trucks.com/forums/8...12-volt-2.html
Old Oct 30, 2010 | 06:17 PM
skipr's Avatar
skipr
thanks Julies but voltage reducers are in other guages work properly
Old Oct 30, 2010 | 06:40 PM
Julies Cool F1
Ok well you have a few real simple possibilities. If the gauge and the sender are matched, they are properly installed with reducers, and properly wired then:
1. The gauge is not working right and needs to be replaced;
2. The sender is not working right and needs to be replaced;
3. Both the gauge and the sender are not working properly and need to be replaced;
or,
4. The gauge and the sender are both working properly and indicating what is really happening out in the engine.
There's no other altrenative!
SteveR1950
Jun 29, 2012 12:34 PM
Jordan84
Dec 6, 2011 09:04 AM
arkk22
1983 - 2012 Ranger & B-Series
Feb 12, 2005 10:55 AM
hungagain
Jan 8, 2005 09:32 PM
