Cam 180* out
Old Oct 21, 2010 | 06:50 PM
dobie6982's Avatar
dobie6982
Cam 180* out
So I put a camshaft in not long ago, and never could get my engine right. It actually ran very well but someting was not right. So today I decided to degree my cam shaft. I tore the front apart and got to my timing chain, and there it was, the camshaft TDC marker was up on top (towards the intake) and the crank pully was TDC. Any ever heard of an engine running like this?
Old Oct 21, 2010 | 09:02 PM
Argess's Avatar
Argess
Not quite sure, but try rotating the engine 360 degrees using the front crank bolt and then check.
Old Oct 21, 2010 | 09:19 PM
White 97 xlt's Avatar
White 97 xlt
Just turn the crank one complete turn and the cam marks will line up.. All is normal!!!
Old Oct 21, 2010 | 09:37 PM
dobie6982's Avatar
dobie6982
I turned the cam and lined them up. The distributer was pointing to the #5 cylinder also. Can you go wrong by doing this and lining the dots back up?
Old Oct 21, 2010 | 09:41 PM
White 97 xlt
Should have turned the CRANK and watched the marks line up like they would have and your distributor wouldn't be pointing at #5 now.....
Your cam IS pit 180 degrees now!~!!
Old Oct 21, 2010 | 09:52 PM
Argess's Avatar
Argess
We were trying to tell you to crank the engine over 1 turn with the timing gears and chain still installed. Crank will turn 1 complete revolution and cam will turn 1/2 a revolution. Marks will then line up
Did you take the timing chain off and turn the cam?
Old Oct 21, 2010 | 09:57 PM
White 97 xlt
In SIMPLE terms the crank turns 2 times every time the cam turns one time..... Originally you just needed to turn the crank ONE more turn and the cam would have turned half a turn and "WOULD have been lined up....
Old Oct 22, 2010 | 09:38 AM
dobie6982's Avatar
dobie6982
Yeah I took the chain off and turned lined them back up. I understand what you are saying about turning one more time though. I just did'nt think about that before hand.
Old Oct 22, 2010 | 10:10 AM
Argess's Avatar
Argess
LOL....it's OK. Now you know. I wouldn't care to admit how many times I out-thought myself.
Old Oct 22, 2010 | 10:27 AM
dobie6982's Avatar
dobie6982
I guess I need to start drinking again. I never out-thought myself back then. Well maybe it will run right now that the cam shaft is flipped. I will be finished tonight and will let yall know.
Old Oct 22, 2010 | 10:50 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
It won't make a difference, except that your plug wires will need to be swapped around the distributor cap 180 degrees
Unless, of course, the marks weren't exactly aligned last time...
Old Oct 22, 2010 | 06:03 PM
dobie6982's Avatar
dobie6982
All is good. Starts better, runs smoother, hoping for better mileage. What do yall usually set your timing to?
tacomacream
1983 - 2012 Ranger & B-Series
Dec 25, 2016 06:23 PM
werefour146
Aerostar
16
Apr 4, 2013 04:14 PM
VetteV12
3.0L V6
Jun 12, 2011 12:11 PM
illusive817
Oct 19, 2009 10:10 PM
royt911
Dec 3, 2008 11:28 PM
