Ignition stuck turning over
Old Oct 21, 2010 | 05:22 PM
masterclean5's Avatar
masterclean5
I've recently posted threads re my fuel problem(solved here!) and getting spark from my ignition coil(could be my distributor, which I'm going to check...). In my attempt to get spark by making quick, short turns of my key, my ignition has gotten stuck a couple of times and nothing I can do can stop it from turning over until my battery goes dead. Hooked up charged battery yesterday and it still is stuck turning over. What do I need to repair or replace to stop this from happening? (I'm sure I also need to stop the quick turns of the key also....) Thanks in advance for your help.
Kent
Old Oct 21, 2010 | 10:12 PM
maples01's Avatar
maples01
Try the starter solenoid out under the hood, sounds like it's hung up.
Old Oct 22, 2010 | 12:09 AM
Hola Man's Avatar
Hola Man
That's actually the starter relay not the solenoid, which is on the starter itself but yeah, that relay is the culprit. A very sharp, hard whack with your fist will get it to stop for now until you can replace it.
Regards, Eric
Old Oct 22, 2010 | 02:22 AM
maples01's Avatar
maples01
It ain't a Chevy, so it won't be on the starter.
Old Oct 22, 2010 | 06:16 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Just pull the wire off the "S" term, if it's still cranking it's the solenoid. If not, either the ignition switch is bad or a wire is shorted in the start circuit.
Old Oct 22, 2010 | 09:43 AM
masterclean5
Where's the starter relay and what's the "S" term?
Old Oct 22, 2010 | 09:53 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Positive battery lead will go to starter relay. Should be two small terminals, one marked 'S" and the other "I". Another large lead will go to starter itself. When you turn the key it energizes relay by applying 12v to the "S" term, closing the relay and sending power to the starter. If the relay is stuck, starter will continue to run even if the voltage from switch is removed. If the ignition switch is bad it will constantly supply voltage to the relay keeping it closed. Hope this helps.
Old Oct 23, 2010 | 12:44 AM
Hola Man's Avatar
Hola Man
That's right, it ain't a Chevy, that's why the relay is not combined with the solenoid which is down at the starter on all makes.
Regards, Eric
Old Oct 23, 2010 | 02:29 AM
maples01's Avatar
maples01
You make NO sense, my 302 has a starter motor ONLY on the engine, no RELAY/SOLENOID etc!
Old Oct 23, 2010 | 06:35 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Here is a diagram for 68-71 Bronco. Might clarify things a bit.
DattMavis
Sep 15, 2015 12:04 PM
Cbad285
Apr 21, 2015 08:05 PM
VaFordman26
15
Feb 17, 2015 09:49 PM
mopjunksuki
Aug 15, 2014 03:50 PM
texasag00
2004 - 2008 F150
May 20, 2012 02:28 PM
