Sponsored by: Real Truck
Tepm Gauge Problem
Old Oct 21, 2010 | 01:13 PM
Ron Mantz's Avatar
Ron Mantz
Tepm Gauge Problem
01 f-250 5.4
Here is my problem the truck starts cold but but dosn't idle well for the first few seconds dosn't seem to want o stay on fast idle, but then runs fine. Temp gauge is normal,if i shut it off while warm and restart it 90% of the time the temp gauge will pin hot and warning light will go on for 5-30 seconds. Then temp shoots back to normal and warning light goes out and truck runs fine.Only one time has it stayed pinned hot for about 5 min and the truck ran terrable (limp mode I think) shut it off and restared it and ran fine and temp gauge normal.I did change all coils and plugs yesturday (saw a service bulliten that said a coil starting to go out can mess with the computer ans cause this) but still the same problem. I'm thinking Temp sensor.What do you guys think?
Old Oct 21, 2010 | 02:15 PM
Kajtek1's Avatar
Kajtek1
Most likely the sensor. When the computer thinks the engine is overheated it will put it in limp mode, or keep on idle only.
For specific answers you might want to go to the section that talks about your engine.
Old Nov 10, 2010 | 11:21 AM
Ron Mantz's Avatar
Ron Mantz
well it looks like I have to change the cylinder head temp sensor,I've read that you have to remove the intake to get at it. It looks like if I remove the alt. I could reach it, does anyone know for sure and how big of a job is it to remove the intake if need be. 2001 f250 5.4
Thanks
lew52
Sep 15, 2013 07:21 AM
Ron Mantz
Modular V8 (4.6L, 5.4L)
Oct 31, 2010 05:35 AM
jfralph
Dec 22, 2004 10:40 AM
nickmobile67
58
Oct 12, 2004 05:33 PM
john crank
Bronco II
Jan 4, 2000 10:43 PM
