installing a 4" downpipe, ??
Old Oct 21, 2010 | 10:57 AM
jacob_powerhouse's Avatar
jacob_powerhouse
what is the easiest way to make more room to fit a larger downpipe.
Old Oct 21, 2010 | 08:36 PM
helifixer's Avatar
helifixer
small porta power between head and firewall. best bet is the 3" to 3 1/2 than to 4'. moving the firewall for a 4" down pipe is a lot of pushing on the firewall
Old Oct 21, 2010 | 10:44 PM
oldbird1965's Avatar
oldbird1965
x2 on what the nice man with the cute puppy said. I put in a 3 1/2 DP and it took me all day with a porta power laying in the snow. I used boards between the head and firewall and between the trans and firewall. I don't think I would do it again. If you have a body lift I heard its easier.
Old Oct 22, 2010 | 11:42 AM
jacob_powerhouse
i decided to drill a hole in the floor and put a bolt through it. i attached a large sliding hammer to that. i drilled like 4 holes and pulled it back. i also did a 3" lift. its a b*tch, lol. it took 30minutes to do and 2 hrs to make my lift blocks
Old Oct 22, 2010 | 11:57 AM
Neal 97 250's Avatar
Neal 97 250
If the tranny is out it is easy. Just takes a hammer and good aim.
Old Oct 28, 2010 | 08:45 AM
2002sport's Avatar
2002sport
A 3 foot 2x4. Wedge it in there and push on it with you feet, then take a big hammer and knock the heck out of it. This was for a 3 1/2 in pipe. I got it in and it touched the firewall, made a horrible resonating sound the cab. Had to remove and bend the firewall some more.
Old Oct 28, 2010 | 09:50 AM
Brown Falcon's Avatar
Brown Falcon
I have a 3" body lift, plenty of room as far as cab clearance, not sure it would clear my tranny lines...
Old Oct 28, 2010 | 11:26 AM
jacob_powerhouse
with my 71mm phat shaft turbo makes it more difficult becuz the exhaust is a little more toward the left side of the truck
Old Oct 28, 2010 | 02:23 PM
strokin'_tatsch's Avatar
strokin'_tatsch
I'm assuming your using an H2E kit or similar to mount the turbo? with the H2E style kits, it positions the turbo straight across. There are some other kits that position the turbo at an angle to make hooking up the exhaust easier.
rupejosh
18
Jan 29, 2009 09:29 AM
strokin71
Mar 21, 2008 09:55 AM
jimwilsonmasonry
Jan 31, 2008 08:57 PM
IAMFORD
Oct 17, 2005 02:30 PM
FTE Ken
Oct 23, 2002 10:13 AM
