4.9 / 300 6cyl performance mods
Old Oct 20, 2010 | 07:03 PM
Lakerat's Avatar
Lakerat
I have a 1977 F150 short box 4x4 with the 300 I6 and 4 speed manual trans. I was considering adding the Clifford intake, Weber 38 2 brl carb, headers, X pipe and dual exhaust combo. Has anyone added these items to there rig? I would like some feedback as to whether it is a good combo, and if the gains are as great as stated by Clifford Performance.
Thanks!
Old Oct 20, 2010 | 08:53 PM
mudder460's Avatar
mudder460
You need to go down to the 6cyl section of the forum, lots of good info there. Maybe a mod can move this for you.
Old Oct 20, 2010 | 08:58 PM
fmc400's Avatar
fmc400
MSEE
I have the Hedman header and dual exhaust on my '79 with a 300 and C6 automatic. There are pictures in my gallery. I'm really happy with how it turned out, but the header was a pain to install. I had to reroute the transmission lines as well as one brake line; I also had to switch to a mini-starter because the standard-size starter can't be removed with the header in place. I also had to shave down the alternator/smog pump bracket (I don't run the smog pump anymore, so I just cut off the top half of the bracket and smoothed it down to fit).
Installing it was a pain as well; I had to remove the passenger-side motor mount and hold the engine up with my cherry picker to place it, and even then it was a challenge to wiggle it in place. Overall a very challenging installation.
I'm running an Offenhauser DP instake and an Edelbrock 1403 carburetor - I'm really happy with those, although the throttle linkage was a challenge as well. In general, the throttle linkage can be hard to set up when doing any kind of upgrade, because of the carburetor's orientation on a straight six. Well worth it though. No idea about the Clifford stuff; as stated the straight six forum would have more info.
Old Oct 21, 2010 | 11:31 AM
Lakerat's Avatar
Lakerat
Thanks for the input. this info helps and I will also brows the 6 cyl section.
cheers
gwindsor
Jul 3, 2016 08:12 PM
jack orchard
17
Dec 27, 2015 12:59 PM
Carloespo
Jun 8, 2015 09:03 PM
krazylegswp
31
May 27, 2015 06:54 PM
Lakerat
41
Jan 31, 2011 01:28 AM
