Part identification please
Old Oct 20, 2010 | 08:18 AM
zoomeroo's Avatar
zoomeroo
I need/want to know what this part number is "02SB-14677 AA" It is a rectangle metal box about the size of a small match box. It is under the dash of my 74 f350.
I don't think it is the horn relay cause i think that is under the hood near the battery.
It has a tab to screw it fast somewhere as well. It isn't a flasher.
Thankss
zoomeroo
Old Oct 20, 2010 | 05:49 PM
dlburch's Avatar
dlburch
it is more than likely D2SB-14677-AA instead of 02SB-14677 AA...
Old Oct 20, 2010 | 06:30 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thats not a part number, thats an engineering number. Ford hasn't put actual part numbers on their parts since 1956.
In Ford's parts catalog basic p/n 14677 crosses to the wiring harness for the rear axle shift motor on B/F500s so I doubt thats correct. Does this look like it was factory installed? How about a picture?
Old Oct 20, 2010 | 09:05 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Does the truck have Air conditioning?
Is it a camper or trailer special?
It sounds like a safety relay of some type.
Pics would help.
Old Oct 20, 2010 | 09:47 PM
steponit's Avatar
steponit
Old Oct 21, 2010 | 01:40 PM
81-F-150-Explorer
That's , not a trailer brake controller. Ford did not have a factory Electric trailer brake controller untill the 21st century. Just the wiring. The customer had to add their own aftermarket one.
What's pictured in the diagram, (erroniously marked trailer brake controller), is in fact a accessory safety relay for the trailer special option. This relay is used for trailer MARKER LIGHT wiring. Taillamps and side markers for the trailer.
Ford uses accessory safety relays like this on a lot of different systems. Early Air Conditioning, Trailer wiring, Marker lamps (Roof lamps, stake bed option etc), Fog Lamps, Dual Batteries... etc...
This is also a diagram for a 1980 and is somewhat erelevant to 1973-1979, and could be misleading. It certainly is misleading with the wrong information added to it.
zoomeroo
2009 - 2014 F150
Jun 14, 2016 12:59 PM
zoomeroo
Dec 26, 2013 07:32 PM
zoomeroo
13
Dec 20, 2013 07:45 PM
zoomeroo
19
Jul 7, 2007 12:45 AM
zoomeroo
Mar 20, 2007 10:59 PM
