installing exhaust y-pipe
Old Feb 24, 2003 | 07:06 PM
idealtrucks's Avatar
idealtrucks
i just put a 360 out of a mid 70s truck in a 71 model. ive already got the t-18 tranny in it and am just now trying to install the y pipe or crossover pipe. im having trouble getting it to go on there. is there any trick to this or is there anything special i have to do?
Old Feb 24, 2003 | 09:19 PM
fast70's Avatar
fast70
the truck should be jacked up in the front try that if that dont work try to give me a better description of whats happening
Old Feb 25, 2003 | 01:57 AM
rebocardo's Avatar
rebocardo
If the nuts are hitting the edge of the flanges, stack some smaller washers under the nuts.
Old Feb 25, 2003 | 10:31 PM
ghak's Avatar
ghak
i just got through doing this. My pickup had a bad clutch and headers, i first replaced the clutch then took out the header because i wanted the quiter stock system.
I got the replacement stock exhaust system from a wrecking yard and it the original factory piece the ford installed. The way i got it in was by taking the engine out and installing it then. I tried taking the transmission back out but the pipe only hit the bottom of the cab. i also tried jacking the pickup up and jacking the engine up and turn the wheels and could not get it in.
I thought maybe i had they had given me the wrong exhaust system, so i brought back too them and they insisted it was it. And they told also that napa sells a two piece y pipe that you can install without jacking the engine up. But i decided on going the low cost route (only cost me 60 dollars).
But if you don't want to do that much work try checking into a 2 piece y pipe.
Old Feb 26, 2003 | 10:05 AM
idealtrucks
thats what i was afraid of. i just got the engine and transmission in ands it really hard to do when you dont have an engine puller. i may get the 2 piece pipe or may just try and run dual exhaust on it
anthony myrick
Dec 7, 2015 02:10 PM
Kdawg89
Oct 11, 2015 08:07 PM
zapola6
Aug 14, 2015 01:14 AM
Anthonynoble
22
Mar 9, 2015 10:07 PM
funtastic
1978 - 1996 Big Bronco
Feb 6, 2004 01:17 PM
