Sponsored by: Real Truck
2006 power stroke diesel speedometer problem
Old Oct 20, 2010 | 12:10 PM
swannman's Avatar
swannman
I was driving today and my speedometer stuck at 35 when I know I was going faster than that. I stopped at a light and it went down to around 19/20 mph. It stayed at that for several miles even when I stopped at several lights. Right before I got back to the house it started to work again. Is there something I can do o fix this issue? Is it common? I don't know if there is a sensor that may need to be cleaned. I called Ford and they told me that the repair may not be covered under my extended warranty, but first they have to run a diagnostic that cost me $100 just to see what to issues is. At this point than they can tell me if my warranty covers it. Any help would be appreciated.
Old Oct 20, 2010 | 03:37 PM
Painted Horse's Avatar
Painted Horse
Seems like that's what happened to me when my differential Speed sensor went out. But that was 3 years ago. So I may not remember exact symptoms. It was a couple hundred dollar repair.
Good luck
Old Oct 20, 2010 | 05:19 PM
bpounds's Avatar
bpounds
The '06 is notorious for having a cluster issue that causes that. Mine has done it twice, both times when I was traveling and could not get it in for replacement. And it fixes itself within a day. Now my warranty is gone, and if it ever becomes a bigger problem I will be stuck with the bill.
You could try a VSS, but if it didn't throw any codes I don't think that will fix it.
Old Oct 20, 2010 | 05:42 PM
dchamberlain's Avatar
dchamberlain
What you're describing sounds more like a cluster problem that a speed sensor problem. You might try unhooking the negative leads to both of your batteries for about an hour, letting the modules reset. This has worked before with other cluster problems.
Old Oct 20, 2010 | 09:22 PM
jorlee's Avatar
jorlee
Also try this. It fixed mine when it did that. The rear diff sensor will wreak havoc with cruise control, shifting, and may set the check engine light.
https://www.ford-trucks.com/forums/6...ml#post4940556
Old Oct 20, 2010 | 10:08 PM
John Irwin's Avatar
John Irwin
Mine screws up all winter. As soon as it get's above 25 - 30 degrees F, it works normally again.
Old Oct 21, 2010 | 05:59 AM
m350's Avatar
m350
My 06' F-350 did it once,,speedo and tach were affected,,within 3-4 hours everything was back to normal,,fixed it self,,,and so far I have Not seen the problem again !
Old Oct 21, 2010 | 09:11 AM
swannman's Avatar
swannman
Thanks
Thanks for all the input so far. I am going to try the battery reset first. I will update to let you know if it repeats.
Old Oct 21, 2010 | 09:51 AM
Diesel 724's Avatar
Diesel 724
My speedo would not start working till i hit 35 mph! No codes no nothing i was puzzled. So i took a shot in the dark and got that sensor in the rear axle and swapped it out, never had a problem again.
Different year truck and all but for the price its worth a shot!
Old Dec 29, 2011 | 07:43 PM
efizzle's Avatar
efizzle
Super Duty Cluster Repair
Have the instrument cluster rebuilt here:
2005 – 2007 Ford Super Duty Gauge Cluster Repair | Circuit Board Medics
Big-Red-Lariat
2011 - 2019 Explorer
Jun 25, 2017 09:27 PM
4x4slik
Oct 10, 2016 09:40 AM
1998F250SC
1997 - 2003 F150
Sep 2, 2016 03:55 PM
AB328
2004 - 2008 F150
Jul 30, 2010 01:10 PM
