Need a smart person!!
Old Oct 20, 2010 | 09:42 AM
johnday's Avatar
johnday
I just registered here, and need help already.
I've got a '90E150, 4.9l auto. I can't get this thing running without using ether. Once I get it running, I have to hold my foot on it or it will stall. Once it warms up, the thing straightens out and will idle normally. The Air Intake control valve is good, as is the Throttle Position sensor, it's a new one. The coolant temp sensor is good. Has new battery as well.
Once I got it started, I disconnected the MAP, the engine started running rough initially, and then straightened out. Is this indicative of a bad MAP?
I've tried pulling codes and keep getting code 77, WOT not detected/operator error.
I've been told of an air temp sensor somewhere on the top of the throttle body, I sure can't find it.
ANY HELP will be appreciated.
Anyone willing to spend some time and walk me thru this? I think the only things left are the MAP and ECM.
Old Oct 21, 2010 | 06:18 AM
johnday's Avatar
johnday
Bump, no one wants to touch it?
Old Oct 21, 2010 | 10:39 AM
65F1005.8's Avatar
65F1005.8
coolant temp or cylinder head temp fits the bill. if they went open thats what it will do.
is it rich?
Old Oct 21, 2010 | 02:17 PM
johnday's Avatar
johnday
is it rich?
Yes, you can smell raw gas as it's cranking. I do have spark. I just went out and tried starting it with ether, no good.
Where is the sensor for head temp?
Thanks for the reply.
Old Oct 23, 2010 | 01:31 AM
65F1005.8's Avatar
65F1005.8
not sure if it has one. but my 5.4L did. it was inside the valley under front driver intake runner.
Old Oct 23, 2010 | 06:11 AM
johnday's Avatar
johnday
That's what I'm wondering as well, does it have one, that is. Someone else said to check the intake air temp sensor. I'd think it would be in the airbox, or maybe in the snorkle, but can't find that one either.I'm beginning to be reminded of why I haven't worked on these things very much since the days of carburetors!
Old Nov 18, 2010 | 05:55 PM
turbogus's Avatar
turbogus
Sometimes I think thank Heavens mines an old carburated 300 '81
Old Nov 18, 2010 | 10:16 PM
Henry10s's Avatar
Henry10s
I am not sure if I can help you, since yours is a 90, mine was a 95. Codes for "operator error" are not uncommon. Ford diagnostics are kinda back and forth, it means that you have to do some things during the test. For example, turn the wheels, or accelerate, or tap the brakes, whatever. "Operator Error" means you are doing something wrong or not doing something. You need to follow the Test procedure. WOT (Wide-open Throttle) Operator Error probably means you should have "pedal to the metal" during the test, but you didn't.
You did not mention if you did a tune-up. Did you?
Don't waste your time on checking single components. Run the diagnostics properly and let the computer tell you.
Old Nov 18, 2010 | 11:51 PM
econoshorty's Avatar
econoshorty
Have you checked the fuel pressure ?
Old Nov 19, 2010 | 04:54 AM
johnday's Avatar
johnday
Thanks for the replies guys, I got rid of it, I just couldn't post because my 'puter was down as well. I guess when it rains, it pours, eh?
Old Nov 19, 2010 | 06:13 AM
JWA's Avatar
JWA
Did you get rid of the van entirely or just the problem? What was the fix or the selling price?
Old Nov 19, 2010 | 07:25 AM
johnday's Avatar
johnday
I sold it for $200, and I never did find the problem. The guy that bought it lives close by, and whenever he fixes it, I'll let you guys know what it was. I'm just a bit overwhelmed right now, and eliminating problem children.
hillbilly469
Aug 28, 2012 08:02 PM
johnday
24
Dec 4, 2010 03:52 PM
master link
Aug 16, 2006 09:46 PM
dongreene
21
Jul 6, 2006 10:45 PM
falcon26
13
Aug 16, 2002 11:28 AM
