Sponsored by: Real Truck
Super Duty getting Ecoboost?
Old Oct 20, 2010 | 07:46 PM
LSchicago2's Avatar
LSchicago2
I wish I could be happy with a truck for 10 years. I usually trade every 4.
Old Oct 20, 2010 | 09:26 PM
Front Runner's Avatar
Front Runner
Neat option if it turns out. Count me out of the line up. No turbo gas engine for me.
Old Oct 20, 2010 | 10:10 PM
BLK94F150's Avatar
BLK94F150
Originally Posted by jc8825
A turbo gas engine will have reliability issues just like a diesel. You notice that you see very few mass-produced turbo sports cars anymore? Turbo is awesome, but it drastically drops reliability that all automakers have to look at for their reputations and warranty claims. In the 80s and 90s, there was the GS-T and GS-X Eclipse, RX-7, Mitsubishi Starion/Dodge Conquest, Nissan 300ZX, Ford SVO Mustang, Dodge Omni Shelby GLH, numerous Chrysler cars (as they were teamed up with Mitsubishi then. Notice how all of the cars that were turbo at some point, were either dropped altogether (at least in the US) or given a non-turbo engine. Turbo engines run like a top for about 100K miles, and then is time to invest serious dollars into replacement and rebuilding of parts.
Honestly, the 6.0 and 6.4 are the only turbo engines that I've noticed consistantly have turbo issues. I also honestly can't believe you're comparing 80s and 90s Chrysler products to anything in reference to quality.
Mike
Old Oct 20, 2010 | 10:42 PM
Tom's Avatar
Tom
Originally Posted by LSchicago2
Ford said every vehicle line will get an Ecoboost option. When will the Super Duty trucks get one, and which engine would it be? I'd bet it would be the 5.0. With twin turbos, the 5.0 EB should make about 480HP & 600TQ or so. If they build it, I will be in line! I'll take a 550 cab/chassis with 120" WB. That should have quite a bit more power and economy over the current V10, without the cost or problems of the diesels.
A couple points I'd like to make here.
First of all diesels are complex because of the turbo systems as well as direct injection. EcoBoost has two turbos and a high pressure common-rail injection system which is nearly as complex as what you'd see on a diesel.
Ford did a lot of work on these engines to make them reliable. The turbos are stainless steel, and are liquid cooled to aid longevity. I have a lot of faith in Ford's engineering lately. Ford is #1 in quality in this country.
You make a great point about Ford's quality. Remember that the 6.7L was designed in-house just the same as the EcoBoost engines. The 6.7L uses a Honeywell liquid cooled turbo just like the EcoBoost. Also remember that the 6.7L PSD has had one of the cleanest launches of any new engine to date, which speaks volumes for something this complex.
I would expect the EcoBoost engines to fare just as well as the 6.7L PSD as far as quality and reliability. So the question is, where's the benefit for reliability?
The new Ford diesel engine should prove to be reliable enough to make purchase cost the biggest reason for considering a gas engine. The EcoBoost isn't a simple engine, nor is it cheap. So where's the market for it? Those wanting a relatively simple, rock solid engine will choose the 6.2L, while those desiring fuel economy and towing power would choose the PSD.
Old Oct 21, 2010 | 09:12 AM
BLK94F150's Avatar
BLK94F150
Diesels also have urea and DPF systems, more frequent filter changes, more oil, higher pressure fuel injection, soot going through everything, higher temps, more coolers.
Other than the high pressure fuel injection, there is nothing brand new on the 3.5EB.
Mike
Old Oct 21, 2010 | 09:31 AM
dkf's Avatar
dkf
A question in my mind is what is what are GM and Chrysler/Dodge/Fiat/Ram/Jeep doing to prepare for the future requirements?
I have to say I give kudos to Ford for looking ahead and getting this EB program off to a somewhat early start. I think starting with the smaller 3.5l EB and working their way up in displacement and GVWR applications is a very logical approach.
Old Oct 21, 2010 | 09:59 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
You might want to look around more In terms of the Powerstroke, that might be true. In terms of "turbo diesels" in general, the turbos are usually a 100K mile-replacement part, if not sooner.
Old Oct 21, 2010 | 11:50 AM
clem1226's Avatar
clem1226
really? I spent 15 years as a heavy equipment mechanic, mostly TD powered equipment that was abused and used hard. Most of our equipment did 2000 hours+, and or over 100k to 130K a year, at that rate we should have been changing turbos on almost every one of out 200 pieces of equipment at least once a year, or if we where lucky every 2 years. 2 years would have been half the stated "expected" life of a turbo.....
reality is several of those pieces of equipment are still on the road with over 1.5 million miles and the original turbo still hanging there on the side of the engine whistling away.Yeah the motors have been in-framed, they generally start using a little oil at over a million miles so you have to throw some new piston packs in there but the original turbos are still chugging away.
you did say "turbo diesels in general" so I assume OTR truck engines are fair to talk about
Old Oct 21, 2010 | 11:58 AM
Wagion's Avatar
Wagion
Doesn't Subaru have turbos in most of their cars? Seems like I have seen a lot of car commercials lately with cars with turbos in them.
Old Oct 21, 2010 | 12:03 PM
bill11012's Avatar
bill11012
Modular motor junkie
******** width="640" height="390"><param name="movie" value="http://www.youtube.com/v/dETvsMzx7C4&hl=en_US&feature=player_embedded&versi on=3"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/dETvsMzx7C4&hl=en_US&feature=player_embedded&versi on=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="390"></embed>*********>
This is what the SuperDuty should get.
driximus's Avatar
driximus
Originally Posted by bill11012
A 480HP 600TQ Twin turbo gas superduty? Now that is the kind of motor that should be replacing the V10!
Word to that!
Honestly I was reading an Article in Diesel Power Magazine, The future of engines have so many ways to go. I personally like what I read in the article.
Develpers at the University of Wisconsin-Madison:
They devolped an engine that was a Gas/Diesel Hybrid. Basically they took a diesel engine and through out the fuel curves they programed and added Gas.
November 2010 Vol. 6 issue 11
The engine Had Near 0% emmisions, And the Thermal efficiency was 60%.
The engine also requires lower injection pressures 7,000ish-12,000ish.
Most current diesels can be converted easily by adding Gas tank, Common port injector and a control module.
NO EMMISIONS EQUIPMENT!! The emmisions on this was Well below current regulations. Bio diesel and E85 is expected to have higher Thermal efficiency.
Old Oct 21, 2010 | 12:25 PM
BLK94F150's Avatar
BLK94F150
I look around plenty and turbos are not a 100K replacement part except in 6.0s and 6.4s.
Mike
  #28
plgebbia's Avatar
plgebbia
7.3L get at least 200,000 out of there tubos, usually longer. I had a 97 F-250 Powerstroke with 349,000 on the original turbo and it was still going strong.
Old Oct 21, 2010 | 12:28 PM
  #29
krewat's Avatar
krewat
Yes, yes I did. I should have said "medium-duty" or some such other qualification, because I was thinking about 3/4-1 ton pickups, and medium-duty trucks like the 450/550 and even the "heavier" medium-duty trucks like the 650/750. Not necessarily Ford, neither.
Old Oct 21, 2010 | 12:34 PM
  #30
plgebbia's Avatar
plgebbia
Orig. turbo on all these (and they all were fine)
99 7.3 170,000
97 7.3 349,000
97 7.3 96,000
95 7.3 337,000 (turbo had 240,000 on it)
95 7.3 249,000
95 7.3 280,000
94 7.3 198,000
