Loud Interior
Old Oct 22, 2010 | 06:30 AM
Atc210's Avatar
Atc210
How well did the rubber flashing work? I want to do this right the first time. Im sure taking everything out of the Ex will be a big project. Did it make a noticeable difference. I like the idea and it makes sense.
Pulled my door panels of the other day and the driver / passenger side doors are missing the plastic sound barrier. Did you only do the floor?
How do you use the quick Quote option?
Old Oct 22, 2010 | 07:34 AM
Shepherd2's Avatar
Shepherd2
It's pretty much the same as Dynamat but not as thick. It's not really a sound proofing per se but more of a deadener. Cuts down vibrations, made a big difference in the doors. Feel alot more solid. You dont really need it on the floors, could get pretty expensive. I also did my inner wheel arches then filled the cavity with bat insulation, or you can spray a heavy coat of undercoating instead, easier anyway. Make sure you get the rubberized stuff, asphalt alone will melt and run when hot.
theSSman
33
Jun 17, 2017 01:19 PM
74F100LGM
19
Aug 28, 2014 05:57 PM
dtlockard
Oct 19, 2011 05:20 AM
mtondreo
Oct 6, 2011 04:53 PM
Keystonepaul
Oct 20, 2010 06:10 PM
