interior lighting options
Well my 97F250 HD extended cab has but one small interior light. What are my best/ doable options to get more light into the interior. I was thinking (always dangerous) that I could pick up one or two interior lights, take down the headliner and install them either side by side forward of the original or in a straight line forward of the original and wire them all together. problems with this? suggestions as to how to do this? Any suggestions on laternatives would be good too. Did the extended cabs( were they called supercabs?) in the XLT version have more than one interior light? and if so can I swap one from a junk yard into mine? any thoughts folks. Thanks, keystonepaul
Do you mean that your truck just has a dome light with no map lights? If so, you should be able to swap in one like this with map lights. Its pretty bright. You can get if from alot of Ford cars and trucks. I got this one on Ebay for about 15-20 bucks. I couldn't stand the dim chrome one anymore. I know the gray is not an exact match. The camera flash makes it look worse than it is. Thats why I'm thinking about getting a black one.
nope sure cant... ive looked almost every where and no one carries them... and as far as plastic paints... uhm have u tired rustoleum or the krylon rust something i forgot... any ways i used the krylon rust tough i think thats it on my door handles several months ago and its still there :P
its the fubared bulb like this
http://www.allfordmustangs.com/forum...s-p1011016.jpg
idk i want something that will swap in easy and not look out of place.... like what the OP is wanting sorry bout thread jacking
yep, that is correct. guess I'll check ebay and junk yard u-pull- it when I get out there.
No apologies needed for taking the thread off in a different direction. It is amazing how dim that light is for sure.
keystonepaul
keystonepaul
quentinorciuch
01-12-2016 07:44 AM
Keystonepaul
15
02-13-2011 06:53 PM
Keystonepaul
09-25-2010 08:47 AM
