203* stat Question..
Old Oct 18, 2010 | 08:02 PM
Krisx125's Avatar
Krisx125
Hey guys,
Just installed my guages the other night. Boost, exhaust temp, and water temp....On the way home my water temp never hot above 160 degrees. Now i have to ask, why do you guys run a 203*? Wouldnt cooler be better?
Old Oct 18, 2010 | 08:15 PM
redman84's Avatar
redman84
I don't know much about them at all but see if this helps at all.
https://www.ford-trucks.com/forums/1...03-t-stat.html
Old Oct 18, 2010 | 08:28 PM
Hussler's Avatar
Hussler
160* is way to cool to run diesel engines long term. Our engines run on heat and not spark plugs. If you ever get it up to 200* + you will know what I'm referring to. Timing is completely different and overall performance is better.
Old Oct 18, 2010 | 09:20 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Plus if you live where it gets cold its nice to have heat in the cab.
By the way Jim nice truck.
Old Oct 18, 2010 | 11:15 PM
rideracelivemx7's Avatar
rideracelivemx7
kris in these trucks the key is a hot block and cold air, the warmer the water temp the better the ignition in the cycles like jim said, it will perform a little better. it takes a LONG time to get up too 100% operating temperature in these, the dummy guages dont tell an accuarate reading. and for the cold air, since its been cold out lately havent you noticed a bit of power? i sure have! lit 3d gear both tires just from a roll in 60t!!
colder air in cylinder temps results in a more efficient burn, hence adding an intercooler! allows for more top end performance. my truck pulls slightly longer on top than it did before. but i say you put on that grille cover you made and do a road test to see the before and after on water temp bet youll see a difference!
Old Oct 19, 2010 | 07:07 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
These trucks have plenty of cooling capacity so even with the warmer t stat it wont get near to over heating.
Old Oct 22, 2010 | 02:10 AM
cowmilker08's Avatar
cowmilker08
What do you think this is a Chevy 6.5?
203* is well worth it.
Bigtruc
20
Dec 26, 2013 10:24 AM
'88 E-350
Oct 29, 2010 07:46 AM
F0rdF0rever
31
Feb 19, 2008 07:38 PM
IceboxFX
29
Jan 19, 2008 10:47 AM
