351w Engine Build
Old Oct 18, 2010 | 07:38 PM
Brian.Hardy's Avatar
Brian.Hardy
Exclamation 351w Engine Build
Hey, I have a stock 351w roller block, that I've cleaned at the machine-shop. I'm wondering if I could make this a 400hp motor for about $3,000 using the stock crank and a set of 351 hypo heads that I already own? And if so can someone please give me a detailed parts list? any advice would be great. thanks in advance!!
Old Oct 18, 2010 | 10:25 PM
Conanski's Avatar
Conanski
A stock shortblock is more than capable of supporting that power level, but unless those "hypo" heads flow as well as AFR 185's you won't get anywhere close to 400hp.
Old Oct 19, 2010 | 04:53 AM
Old Hickory's Avatar
Old Hickory
You need some really good aftermarket cylinder heads to make 400HP.
Old Oct 19, 2010 | 10:01 AM
Kemicalburns's Avatar
Kemicalburns
what they said. now the next important question. whats this motor going into
Old Oct 19, 2010 | 12:21 PM
Brian.Hardy
A 1967 coupe mustang with a T5 transmission behind it. Well. Including a new set of heads could I still get 400hp for around $3000
Old Oct 19, 2010 | 01:36 PM
Conanski's Avatar
Conanski
A pair of iron RHS heads will do it for a little over $1000 a pair.. Racing Head Service (RHS) 35304-01 - RHS Pro Action Small Block Ford Cylinder Heads - Overview - SummitRacing.com
What you're looking at in this simulation is a stock bottom end with 0.030" over pistons , 58cc RHS heads, the Comp 35-420-8 roller cam, a high flow intake like the Edelbrock Performer RPM Airgap with a 750cfm carb, and of course a full exhaust system with headers.
Old Oct 19, 2010 | 06:18 PM
Old Hickory
Nice torque curve and good power. Would be great in a Mustang or a hot rod truck.
torino_man
Sep 27, 2018 10:07 AM
pete e
Sep 29, 2011 10:06 AM
Buckin_Bronco
19
Nov 12, 2009 12:41 PM
v10squirrel
Jul 10, 2007 08:54 PM
1982_f150
Engine Swaps
Jul 9, 2007 11:07 AM
