broken throttle lever
Old Oct 18, 2010 | 06:36 PM
aaronlaaron's Avatar
aaronlaaron
Hi I have a 93 idi turbo and I have broken the throttle lever. ( the part that the cable attaches to and has the idle adjustment on it. I looks like I would have to slide the shaft right out of the injector pump to replace it. Any tricks to getting it off???
Old Oct 20, 2010 | 12:59 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
You ain't going to like this answer ... Replace the Pump with a Reman from Pensacola!
No core!
-Enjoy
fh : )_~
Old Oct 20, 2010 | 01:49 AM
LCAM-01XA's Avatar
LCAM-01XA
Where exactly is it broken? You can always attempt welding up the broken pieces, I've welded throttle body levers on gasser engines without damaging or warping anything so I can't see why it couldn't be done to an IP as well... Best case you fix your problem, worst case you can always do like Festus suggested.
Old Oct 20, 2010 | 11:03 AM
WarOzz's Avatar
WarOzz
Post up a pic, will be easier to tell you if it could be welded or not.
Old Oct 20, 2010 | 11:24 AM
LCAM-01XA's Avatar
LCAM-01XA
Yah, that's true...
Old Oct 23, 2010 | 02:07 PM
aaronlaaron
thanks, your right I don't like that answer I might try to weld it in place. I don't really want to replace the pump as it is not even 12 months old. It must of got damaged when the the engine was dropped in...
Old Oct 23, 2010 | 07:05 PM
LCAM-01XA's Avatar
LCAM-01XA
Use MIG or TIG for that weld, and be very easy on the power - it's not sheetmetal, but it ain't a frame rail either. Better find something to practice on before you actually attempt welding it up...
Old Oct 24, 2010 | 01:42 AM
aaronlaaron
thanks once again. welded it in place with a tig. used the air comp to cool it between spots, worked awsome..
Old Oct 24, 2010 | 10:55 AM
LCAM-01XA's Avatar
LCAM-01XA
Oh, good!
Old Oct 24, 2010 | 11:05 AM
WarOzz's Avatar
WarOzz
Good to hear you got it fixed, welded like that it should last a long time.
KhanTyranitar
Aerostar
Nov 6, 2012 08:16 AM
Powerstroke-7.3
May 1, 2011 05:18 PM
RXRR
Jan 23, 2006 07:24 AM
denisontexas
Jul 16, 2002 09:46 PM
FirstF150
Feb 11, 2002 08:45 PM
