6.7L Engine Design
There are two primary test methods that are used. Note that I've tried to write this so that those unfamiliar will hopefully have a better understanding of these tests. The Fourier transform infrared (FTIR) gas chromatography or just infrared or IR test for short, tests for water and glycol content, fuel dilution, oxidation, nitration and soot index. For those not familiar with the Infrared analysis, it's the most widely accepted test method in the industry today to determine lube condition. The test in it's basic form looks for Contamination Oxidation, Sulfation, Nitration, Water, Antifreeze and Soot and degradation of the oil in general (detergents, etc.)
Then there's a 2nd test, the base metals trace test, derived from the normal wear debris from the various metallic components. These particles are the result of rotating or sliding component within the engine assembly (pistons, rings, bearings, crank, etc.) The ASTM D5185 globally standardized test is pretty much the benchmark criteria used in the industry also known as atomic emission spectroscopy. It looks for pretty much any of the base metals used today, aluminum, boron, barium, calcium, chromium, copper, iron, lead, zinc, etc. etc.
So between the Fourier transform infrared (FTIR) gas chromatography with mass selective detector (GCMS) and the Inductively coupled plasma (ICP) you now have a nice overall snapshot of all the data needed to evaluate oil condition. This can then be used as an indicator to determine a number of things such as how well a particular oil stands up for a given application or how well an engine assembly is wearing.
The important piece of information here is that each test is only a snapshot in time. For this data to have any useful meaning, you really need to have multiple test results to correlate the data over a period of time (compare test results from multiple oil changes). And yes, the initial oil change will almost always have the highest levels of trace metals due to the initial break-in period. Imho, the results of the first oil change, at least for trace metals should be omitted when the data is gathered from a mass produced engine. This is normal, and has little correlation value. However, in the event of catastrophic failure, oil analysis is crucial for root cause analysis.
There are also some control factors that need to be observed such as making sure the same oil type is being used, the same fuel is being used, etc. This will help to eliminate variability in the test results by uncontrolled outside factors. This can have a significant impact on the test results and potentially lead to incorrect conclusions. It's also helpful during the testing process if there's a sample of the original unused oil. This helps determine a baseline of the oils original properties in relation to the used oil.
Now having said all that, you might be interested to know that most powertrain OEM developers rely on external 3rd party experts to perform these oil tests. Companies like Southwest Research Inst. design and develop comprehensive lab environments on a large scale for the sole purpose of providing unbiased reliable test data using latest measurement technologies. They provide this for the automotive, airline (turbines), military and pretty much any industry that uses lube oils.
Hope this helps!
-Paul
I do not know if you have seen all of Paul's posts regarding the 6.7 design. He actually covered the dipstick location in another post. He commented about how that was a very difficult item to engineer given the layout of the engine. Surely the oil fill situation is similar. He also has addressed the ease of serviceability issue from the last 2 engines.
Regards
