Injector contribution
Old Oct 17, 2010 | 06:57 PM
Visseroth's Avatar
Visseroth
OK, so I remember seeing a thread where we were talking about injectors so I decided to run some tests myself but in the AE tool for live data meter I don't see anything that allows me to read the contribution for each cylinder.
However when I run a KOER test I get P0284: Cylinder 8 Injector Circuit Contribution / Balance Fault.
Anything to worry about and how can I run more tests on my injectors?
Old Oct 17, 2010 | 07:21 PM
PaysonPSD's Avatar
PaysonPSD
Viss,
Click on Test OnBoard System just like you did for KOER test. Under KOER drop down menu look for Cylinder Contribution Test. EOT should be 140 degrees to run the test. Engine at idle and all accessories off until test ends.
If you have a gray CPS #8 will always show a CCT balance fault. #3 can also fail with the gray CPS.
Old Oct 17, 2010 | 07:37 PM
F350-6's Avatar
F350-6
On the AE live data tab, it's called Change in Rotational Velocity Cylinder 1, Cylinder 2, etc. You can select each cylinder on the live data tab and still have one more box to watch things. I like to fill the last spot with EOT so I can try and compare things near the same temperature.
Old Oct 18, 2010 | 12:51 AM
Visseroth's Avatar
Visseroth
Ahh, ok. Well I ran the test. Haven't looking at the live data yet. I'll do that tomorrow and get a snap shot but I have a black CPS. I changed it out as soon as I found out about the grey CPS not long after buying the truck.
Anyhow, I will get a screen shot of the live data tomorrow after running the truck around a bit and getting her warmed up.
Oh, and when I ran the test my oil temp was at 165.
Old Oct 18, 2010 | 01:05 AM
PaysonPSD's Avatar
PaysonPSD
If you do not have some type of fuel return kit that opens up the dead end fuel rail on the driver side #8 is not getting the proper amount of fuel and may cause the contribution fault. Could be that #8 is just getting more worn out then the others because it doesn't get as much fuel and therefore not as much lubrication in the fueling part of he injector.
I haven't found a way to look at live data for the CCT. I have never seen it show up on the live data grid or the live data meters like the rotational velocity test. If you find a way let me know.
Old Oct 18, 2010 | 01:29 AM
Visseroth's Avatar
Visseroth
Will do, I'll be playing with it, but in regards to the #8 I do have Clay's FRx kit for the fuel, but I bought the truck used and it may be that it's already a bit worn out and may need to be replaced. However when I go to do the injectors I plan on doing them ALL at once.
If I remember right Clay or someone else stated the best to get if you are going to stay stock is the AD's.
Old Oct 18, 2010 | 01:32 AM
Visseroth's Avatar
Visseroth
As a side note an injector buzz test sounds great on my truck, they are all nice and loud.
Old Oct 18, 2010 | 09:53 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
You are unable to run a rotational velocity on early 99 trucks unless you have swapped in a later PCM though.
Old Oct 18, 2010 | 10:05 AM
mongo75's Avatar
mongo75
So that's why mine showed no faults huh? I gotta question, so if the grey CPS is bad enough, what would cuase a black one to show cyls 1, 4, and 8 to be off? I've asked this before, and got the usual answer that 8 is always gonna be off, but with a regulated return you'd think that the fuel situation is taken care of, so it's gotta be a "bad" CPS? I know there's no moving parts in the CPS to go bad, but I would imagine they can and do get out of sync or alignment or whatever it is that keeps them firing your injectors properly, right?
Old Oct 18, 2010 | 12:45 PM
PaysonPSD's Avatar
PaysonPSD
#8 will show a contribution fault after running a CCT with a brand new gray CPS.
I can pass CCT with this newest CPS,on right, or the Black International. I have a Black one installed now. Always passes CCT.
Edit : AD codes can supply a larger volume of fuel then ABs. Definitely go with the ADs.
Old Oct 18, 2010 | 02:40 PM
mongo75's Avatar
mongo75
The thing is is that I'm running the black, I think it's time for a new one maybe, I might try swapping the grey one in to see the difference. As soon as the dealer put the grey one in, I took it home and swapped it with my black back up. Thanks for posting the pics with the part number!
Old Oct 18, 2010 | 03:57 PM
PaysonPSD's Avatar
PaysonPSD
Just to make things clear the one on the right in the other post, DU-87, is the newest out at Ford. It's a blue that is nearly black with a purple o-ring.
This is the Black INTL.
Old Oct 18, 2010 | 06:13 PM
Visseroth's Avatar
Visseroth
OK, well checked for the Rotational.... and it's not listed, Clay is right :-( Going to have to update my PCM at some point, I'm tired of not having all the things I should have on this old PCM.
I also ran the KOER Cylinder Contribution test and still get P0284. Probably should just replace the injectors at some point. I have lots of things to do on this truck, just not a lot of money atm. I can't wait to start making some real stinking money!
Old Oct 19, 2010 | 11:45 AM
mongo75's Avatar
mongo75
Why did Ford come out with another CPS? Is it better than the grey, or just another fumble by a different color?
Old Oct 19, 2010 | 12:16 PM
superduty4x4's Avatar
superduty4x4
Its the fix for the grey CPS...
