4wheel drive probs
Old Oct 17, 2010 | 06:56 PM
91dirtydiesel's Avatar
91dirtydiesel
4wheel drive probs
put the the truck in 4 wheel for the first time since the axle swaps and the front felt like it was skidding around the turns, havent looked into it yet but just wanted to see if there was any thing to look for that may cause it?
Old Oct 17, 2010 | 07:02 PM
wreckinball's Avatar
wreckinball
are you going slow when it is "skidding?" If so that is pretty normal. If it is at higher speeds then you need to make sure you have the same gear ratio. Mine will do little hops at low speeds but it specifically does it when you have the wheel cranked left or right. It is in the the fact that when you have two locked axles and one wheel is turning less or more than the other, it will hop or skid the "slower" wheel.
Old Oct 17, 2010 | 07:09 PM
91dirtydiesel
yea it was only at slow speed, havent tried it any faster than 30mph yet so well see what happens, just matched the gear ratios today
Old Oct 17, 2010 | 07:37 PM
wreckinball
locked in at 4wheel or 4low my truck hops a little at slow speeds. Pretty damn normal.
Old Oct 17, 2010 | 07:41 PM
91dirtydiesel
Well that's good to know!
Old Oct 17, 2010 | 08:23 PM
ManicMike's Avatar
ManicMike
If it's a open diff though, why would the tires hop? (mine does it too, only when in 4wd and at low speeds turning full lock or close to it). This is of course on dry pavement. I'm sure you couldn't notice it on dirt/mud/snow.
Old Oct 17, 2010 | 08:53 PM
wreckinball
I dont know the physics to a p but i do know that almost any 4wheel truck will skip or hop a little when cranking the wheel and rolling slow. on mud, no because you would slip freely. dry pavement isnt so forgiving as slippery mud or similar.
Old Oct 17, 2010 | 09:03 PM
87crewdually's Avatar
87crewdually
Because your changing tire rotation characteristics between the front and the the back axles.
Old Oct 17, 2010 | 10:51 PM
rodneywar's Avatar
rodneywar
he is right thats why it is really recommended not to drive in 4wd on pavement ur risking grenading the transfer case or something you need to allow the wheels to slip some in 4wd
bigtexan99
Feb 10, 2013 10:41 PM
fjatheart
Feb 5, 2011 11:41 AM
Wozzie06
1997 - 2003 F150
Sep 9, 2002 03:39 PM
