no start-fuel problem
Old Oct 16, 2010 | 06:52 PM
andyman7931's Avatar
andyman7931
Still trying to get my truck running after a jump starting mishap. Right now there is spark, the fuel pump runs for 2 seconds when you turn the key, but the engine won't start. I tried on both fuel tanks, but no luck. Any ideas?
The history of the problem... truck sat for 3 weeks with the GPS on, battery low. Jumped it off and then the starter solenoid stuck and the starter turned fast. I had to replace both the starter and solenoid to get the starter to turn but then had no spark. I just replaced the coil+ignition module and now spark is back, but no fuel.
Old Oct 16, 2010 | 07:23 PM
subford's Avatar
subford
Put a noid light on one of the injectors plug and see if it is firing the injectors.
Old Oct 16, 2010 | 09:29 PM
g_k50's Avatar
g_k50
fuel pressure? Timing check statically?
Old Oct 17, 2010 | 06:41 AM
andyman7931
Thanks for the responses, I think I know what's wrong now. I took the distributor out to swap the ignition module and I bet I didn't get it put in right so the timing is way off. I'll check that first thing today and go from there. I was in a hurry putting it together last night before daylight left, sometimes it doesn't pay to rush...
Thunderbird7480
Feb 9, 2020 02:51 PM
Uncle Paul
May 22, 2014 09:33 AM
Rich1953ard
Apr 28, 2013 10:34 AM
RCM
1983 - 2012 Ranger & B-Series
Jun 30, 2009 05:37 PM
unisphere
Nov 2, 2008 07:34 AM
