dead battery?
Old Jun 30, 2009 | 03:18 PM
RCM's Avatar
RCM
dead battery?
'96 2.3L w/ 187k miles
3yr old alternator (replaced original) and battery
2 mo. old clutch interlock switch/starter relay (both original)
replaced original starter last night.
Truck had a tough time starting on Sunday so I shut it off and tried again - nothing. Bi-passed the starter solenoid, sparks but didn't start. Tapped on starter as wife turned the key, started but with a bad grinding noise. replaced starter - Duralst LLT warranty from Autozone.
Its been started 8x since I replaced the starter and has been driven 70 miles (mostly hwy) but just left me stuck in the grocery store lot. Tied to jump it and heard about 3 clicks but wouldn't start. Tried again and nothing once I turned the key. No door beeping, radio, or lights.
Waiting for the wife to get home so I can get back to the truck.
I'm assuming the battery but just wanted to make sure. Thougts?
Old Jun 30, 2009 | 03:45 PM
Traxxis's Avatar
Traxxis
Hmm... generally if it is a bad battery, you can still jump it. You might try a load tester, or atleast get it running, take it to walmart or an auto parts store and have them load test it.
Have you checked the battery connections? Maybe clean the posts and terminals.
STan
Old Jun 30, 2009 | 05:37 PM
RCM's Avatar
RCM
posts/terminals are clean
checked all connections: battery>starter relay>solenoid>starter. Everything seemed clean and snug.
it started after the 4th attempt. It either got some power (a beep or two) or it was dead before that. It appears to be either the ignition switch or ignition (lock/key). The ignition was able to be started w/o a key for a while or the key could come out while running. I figure I might as well replace both while I am in there plus they are cheaper than a new battery.
98F150on33s
1997 - 2003 F150
Nov 26, 2014 11:28 AM
dbail3
Electrical Systems/Wiring
Sep 18, 2014 07:07 PM
Singing River Farm
18
Jan 25, 2014 03:51 PM
bigfix
Jan 1, 2012 05:39 PM
Boyd
15
Feb 3, 2005 08:06 AM
