HELP!!!!!
Old Oct 16, 2010 | 12:35 AM
big78f150's Avatar
big78f150
HELP!!!!!
i have an 89 lincoln mark vii with a 5.0 HO, if i go fast or cut a hard left it kinda boggs down till it straightens out then its fine, dont do it if i turn right at all. i do race the occasional ricer and noticed the past 2 weeks or so if it gets around 3000 rpm its kinda like it bogs down from not enough fuel, and also it has been backfiring when turning left and when its first started and you give it more then a 1/4 pedal till it warms up. head gaskets were replaced about a month ago by me but this problem existed before i tore it apart, except for the backfiring when i turn left. hope this aint too confusing lol.
Old Oct 16, 2010 | 09:44 AM
Conanski's Avatar
Conanski
Check fuel pressure, should make 40-45psi at the rail with vacuum removed from the regulator. Also pull the codes to see if naything is flagged.
Old Oct 16, 2010 | 09:54 AM
big78f150's Avatar
big78f150
no codes are coming up. im thinking its the fuel pump or the presure regulator. my gas gauge has been on the fritz too
Old Oct 16, 2010 | 07:14 PM
Beanscoot's Avatar
Beanscoot
The fuel pump is definitely a possibility. I would look first for a partially clogged fuel filter, although the bogging in hard left turns is a bit of a head scratcher. Maybe some fault with the fuel pickup that allows it to suck air when the fuel sloshes over to the right side?
Old Oct 17, 2010 | 10:46 AM
big78f150's Avatar
big78f150
fuel filter is new. just replaced a few weeks ago
Austin J.
Aug 26, 2012 06:02 PM
supermandn59
1983 - 2012 Ranger & B-Series
Feb 17, 2011 07:38 AM
pidaster
13
Nov 8, 2009 10:43 PM
Vinford
Feb 4, 2009 01:04 PM
strokermotor91
Jun 7, 2007 11:25 PM
