Poly or rubber engine mounts??
Old Feb 24, 2003 | 08:57 AM
MustangGT221's Avatar
MustangGT221
I need help quick. I just sent my truck in to have them check the engine mounts for a klunking noise. If it comes to be that the mounts are bad, what should I get, poly or rubber? I can get a sweet deal on the poly. They are usually like $300 and I can get them in the $150 range. The only concern is that am I going to feel a lot of vibration and such from the engine with the poly? I might change to a built 351 with about 350-400hp in the future so since the mounts will work with both engines, I'd like to get a set that will work with both. Is poly the way to go? Or should I just get the rubber ones? My friend has a 350hp mustang and the rubber ones didn't last very long at all so he switched to poly.
Old Feb 26, 2003 | 04:52 AM
DeenHylton's Avatar
DeenHylton
Go with the poly, just don't mix...if you use poly engine mounts you need to use a poly tranny mount. I use poly on my 600 plus HP Vette with no problems and no noticable increase in vibration. Deen
lafermedavid
Mar 17, 2023 04:08 PM
f100today
May 28, 2016 08:07 AM
Ziob
Jun 7, 2015 07:23 AM
Jarryd
31
Apr 26, 2015 04:16 PM
Schuyles
Jul 25, 2014 12:51 PM
