Auto trans problems
Old Oct 15, 2010 | 06:23 PM
81Bronk36's Avatar
81Bronk36
Auto trans problems
My truck didnt want to drive forward when the trans is cold. I found that the fluid level was low so I added Lucas trans fix and a quart of b&m slick shift and it was perfect afterwards. Not being able to leave well enough alone I decided to change the fluid and filter and I also added a remote filter kit. For 2 days it funtioned fine, then started acting up again so I added another bottle of Lucas and it helped a little. I do know that I suck at installing rubber gaskets and my pan gasket leaked both before and after but the first 3 days after the fluid change the level was good, or a little high and it was still not wanting to go forward when cold. Basically I back it out of the driveway into the road and put it in drive, wait about 30 seconds, get tired of that so I give it some gas, then if I am lucky about 20 seconds later it will jump forward and work fine. Could it be the torque converter?? Pump? Valve body?
Old Oct 15, 2010 | 06:45 PM
joe f350's Avatar
joe f350
what trans c-6 or e40d
Old Oct 15, 2010 | 08:10 PM
81Bronk36's Avatar
81Bronk36
Sorry its a C-6, I should make a signature
Old Oct 16, 2010 | 08:30 AM
kenpobuck's Avatar
kenpobuck
You are sure it is full, checked whet hot in park? Sounds like it is a little low on fluid. If not then it could be the pump is getting a little tired and needs the extra revs to get the pressure up. If it is going I would swap it out for a good manual lol. I still have the c6 out of mine laying in the shed and will never miss it.
Old Oct 16, 2010 | 08:52 AM
Lazy K's Avatar
Lazy K
If fluid level is OK then my guess would be hardened/worn forward clutch servo seals.
Old Oct 16, 2010 | 01:57 PM
81Bronk36's Avatar
81Bronk36
The level is perfect on the stick, it hasnt leaked very much in 2 days so I think the final level is even with the pan gasket. I wonder if it really needs a little more in it since it seams to work pretty good before it sits for 2 or so nights and theres a puddle on the ground a little smaller then a small bath mat.
The intermediate servo seams to be leaking as its completely clean below it. Can it be removed with the trans in and nothing will fall out so i can put a new gasket in? Is there even a gasket behind it?
I do need to install a thermostat on the cooler, as the lines are never really that warm and my gauge that I just installed has never registered and its lowest temp is 140.
Thanks for the help guys.
granny_rocket
Nov 19, 2013 10:57 AM
Motormanhbg1
Apr 11, 2012 09:57 PM
Magick_Man
Aug 19, 2008 09:35 PM
mattmonson
Feb 20, 2005 07:37 AM
JBronco
1978 - 1996 Big Bronco
Feb 8, 2005 08:25 PM
