I am not guru at this. What part is this? Some sort of stabilizer arm or something? The bottom bar loops around to the other side and both ends attach to the other bar you see bolted to the frame. This picture of take from the middle of the van facing the back. Thanks in advance!
It looks like I am probably dealing with a rear <a href="http://www.google.com/images?um=1&hl=en&biw=1595&bih=865&tbs=isch:1&sa=1 &q=sway+bar&aq=f&aqi=&aql=&oq=&gs_rfai=">sway bar</a> and a broken sway bar link. I can't seem to find the same link though.
2001 E350 SD LX. Looks like <a href="http://www.autopartsdeal.com/catalog/detail.php?R=universalenergysuspe1298149r+universa lenergysuspe1298125r+universalenergysuspe1298125g+ &B=Tj05MjUwJk5yPU9SKEFORChtYWtlOkZvcmQsbW9kZWw6RS0 zNTArRWNvbm9saW5lLHllYXI6MjAwMSksQU5EKHVuaXZlcnNhb DoxKSkmVmk9MTYxNisxMDM0NCs0Mjk0OTYzMzY0Jnk9MjAwMSZ taz1Gb3JkJm1kPUUtMzUwK0Vjb25vbGluZQ%3D%3D&T=U3dheS BCYXIgTGluaw%3D%3D&ymm=true">these</a> are my choices b/c the factory links are not the same - as you can see where the link attaches to the frame. When I look up this year it shows a link with a 90degree angle bolt assembly with bushings. The one on mine is just straight.
