torque spec
Old Oct 15, 2010 | 04:21 PM
rodneywar's Avatar
rodneywar
torque spec
any body know what the torque spec is for the intake and exhaust manifolds are and i need to take my exhaust off so can i reuse the gaskets for the exhaust i just put them on 10000 miles ago thanks
Old Oct 15, 2010 | 07:20 PM
rodneywar's Avatar
rodneywar
bump!!!!!!!
Old Oct 15, 2010 | 07:23 PM
LCAM-01XA's Avatar
LCAM-01XA
If the intake bolts are 5/16" (take 1/2" socket) then go 35 lb-ft on them, this is what most intakes with such bolts call for. Dunno on the exhaust questions tho...
Old Oct 16, 2010 | 12:11 AM
87crewdually's Avatar
87crewdually
TORQUE SPECIFICATIONS TORQUE SPECIFICATIONS
Application Ft. Lbs. (N.m)
Camshaft Gear Allen Screw 15 (20)
Connecting Rod Nut Step 1 38 (51) Step 2 51 (69)
Cylinder Head Bolt (*1) Step 1 65 (88) Step 2 90 (122)
Step 3 100 (135) Step 4 100 (135)
Exhaust Manifold Bolt(*2) 35 (47)
Fan Clutch-to-Water Pump Nut 45 (61)
Flywheel-to-Crankshaft(*3) 47 (64)
Glow Plug 12 (16)
Injector Nozzle 35 (47)
Injection Pump Gear Bolt 25 (34)
Injection Pump Gear Cover Bolt(*3) 14 (19)
Intake Manifold Bolt(*4) 24 (33)
Main Bearing Cap Bolt Step 1 75 (101) Step 2 95 (129)
Oil Cooler-to-Cylinder Block Bolt Front Header 24 (33)
Rear (Filter) Header 14 (19)
Oil Pump Pick-Up Tube Bracket-to-Main Bearing Cap Nut 14 (19)
Oil Pump Pick-Up Tube-to-Oil Pump Bolt 14 (19)
Rocker Arm Bolt 20 (27)
Vibration Damper Bolt 90 (122)
Water Outlet (Thermostat Housing) 20 (27)
Water Pump(*3) 14 (19)
INCH Lbs. (N.m)
Rocker Arm Cover Bolt 72 (8)
NOTES:
(*1)At steps 1 and 2, tighten bolts in numerical sequence beginning with bolt No. 1. At steps 3 and 4, tighten bolts in line sequence beginning with bolt No. 15. See Fig. 3 .
(*2)Tighten to specification in numerical sequence beginning with bolt No. 1, then tighten again to same specification in line sequence beginning with bolt No. 4. See Fig. 2 .
(*3)Coat threads with thread sealing compound.
(*4)Tighten to specification in numerical sequence beginning with bolt No. 1, then tighten again to same specification in line sequence beginning with bolt No. 9. See Fig. 1 .
This may help
Old Oct 16, 2010 | 12:30 AM
LCAM-01XA's Avatar
LCAM-01XA
24 lb-ft, darn - any idea why an IDI with grade-8 bolts uses less torque on said bolts than a small-block with grade-5 bolts? Seems kinda odd to me...
Old Oct 16, 2010 | 09:14 AM
rodneywar's Avatar
rodneywar
thats really odd i thought it would be higher
Old Oct 16, 2010 | 09:29 AM
87crewdually
These are stock specs. Since I'm turbo charged, after I met the torque value I went an additional 1/8 or 45* of a turn on the intake manifold bolts.
Old Oct 16, 2010 | 09:33 AM
rodneywar's Avatar
rodneywar
i am turboing the truck tmw i am also building my own gp harness cause the old one is a crappy design i was thinking i would go 29 ft lbs with the intake i dont trust degrees
Old Oct 16, 2010 | 09:46 AM
87crewdually
Don't trust degrees? Many manufacturers use that method for headbolts and such. Alot of inconsistencies any other way really. With those inconsistancies your 5 ftlb increase isn't increasing much hold. Just my experience, it's only an intake with 3/8" bolts so I'm sure it will be fine.
Old Oct 16, 2010 | 12:25 PM
LCAM-01XA's Avatar
LCAM-01XA
Oh, so they are actually 3/8" bolts, and not 5/16"? Then the low torque spec is even more odd then... Oh well, I'm sure he IHC people knew what they're doing on those. And yes the degree method works good, this is just how you set the preload on lifter with the rocker arms - well, never done it on an IDI, but at least on gassers this is how it's done, tighten to zero-lash then give it a fraction of a turn more and it's done.
rdmobile
Modular V10 (6.8l)
May 11, 2020 10:42 PM
gammatino
Nov 8, 2015 01:46 PM
C350CREW
Nov 2, 2010 10:25 AM
ChunderDownUnder
Nov 18, 2009 01:56 AM
GOT 7.3 ?
Jul 2, 2009 09:59 PM
