6 liter tune up
Old Oct 14, 2010 | 11:34 PM
dsands88's Avatar
dsands88
6 liter tune up
Hey can some one tell me the parts required for the 6 liter tune up thanks ive tried searching to.
Old Oct 14, 2010 | 11:57 PM
Encho's Avatar
Encho
The Southernmost Mod
A good coil (MSD, ACCEL) and set of wires (MSD, Ford Racing ACCEL), Motorcraft or Autolite sparkplugs (gapped at .055). I thinks that's pretty much all the parts you need if i recall it right.
If anyone remembers anything else feel fre to add it.
Old Oct 14, 2010 | 11:59 PM
dsands88's Avatar
dsands88
and advancing the timing right?
Old Oct 15, 2010 | 01:02 AM
86F150302's Avatar
86F150302
That is correct.
Plus a nice MSD cap/rotor
http://fullsizebronco.com/forum/showthread.php?t=63592
Old Oct 15, 2010 | 01:17 AM
ymeski56's Avatar
ymeski56
Der Postmeister
See this link:About the Ign. sys./timing bump. - Ford F150 Forum - Community of Ford Truck Fans
Check out Taylor Thunderbolt wires too & the higher the turn ratio on the coil, the better. Accell makes a 132:1 48K coil, compared to MSD's 83:1 48K coil. Go w/ the Accel. Turn #'s may vary slightly, as working from memory, but accurate w/in a few of turns.
Old Oct 15, 2010 | 08:00 AM
Encho's Avatar
Encho
You asked for parts, not procedure...
"the higher the turn ratio on the coil, the better" Why's that Ymesky? haven't read this before.
Old Oct 15, 2010 | 09:42 AM
ymeski56's Avatar
ymeski56
Der Postmeister
Allows for a lower primary resistance for higher output coils. Primary resistance being the amount of resistance required to be overcome, to initiate plug spark. Preferable for our application. Especially when stretching plug gaps w/ copper cores. Fat, happy spark kernels!
Old Oct 15, 2010 | 12:50 PM
thechief66's Avatar
thechief66
"6 liter tune up" ???
6 liters is about 366 cubic inches...WTF?
Old Oct 15, 2010 | 01:07 PM
JJ3's Avatar
JJ3
Call it what you will, it really woke my truck up. I was only able to get 12ish* on the timing. I also cut off 1 cat and installed a flowmaster knockoff muffler. WELL worth the 200.00 I spent.
rla2005's Avatar
rla2005
Sixlitre is one of the frequent posters on the Fullsize Bronco forum. The tuneup was named after him.
Old Oct 15, 2010 | 01:38 PM
hav24wheel's Avatar
hav24wheel
That Accell coil left me sitting along the side of the road after it being on there for only acouple weeks. I have a MSD now, and the old factory one under the back seat for a "just in case"
Old Oct 15, 2010 | 02:07 PM
ymeski56's Avatar
ymeski56
Der Postmeister
So'd my 60K Pertronix. Installed another one & it's been going for 4 yrs. now.
Sometimes s**t happens! Everybody has "fail" stories. I keep my old stocker under the seat too, along w/ my old serpentine, fuel pump relay, couple of plugs, The best longest plug wire from the last set, ect...
Old Oct 15, 2010 | 09:04 PM
skyfox10's Avatar
skyfox10
I'm surprised no one here said anything about copper vs platinum plugs. When your getting plugs, if it's a 300/302/460 use Autolite 25's, if it's a 351 get Autolite 24's... Or the Motorcraft equivalent.
Old Oct 15, 2010 | 09:55 PM
ymeski56's Avatar
ymeski56
Der Postmeister
I covered it in this link:About the Ign. sys./timing bump. - Ford F150 Forum - Community of Ford Truck Fans
Ooduce4knot
Sep 24, 2016 08:42 PM
The_Drew
Jun 22, 2016 08:12 AM
1st4x4 beach truck
Aug 20, 2015 06:57 PM
garrett_8
Nov 21, 2012 02:53 PM
FordYoungGun35
18
Aug 3, 2012 09:28 AM
