Limp mode
Old Oct 13, 2010 | 07:55 PM
transamz9's Avatar
transamz9
Limp mode
I have an 06 F350 CC for a company truck and I was hauling another truck in from a job the other day and the 6.0 went into limp mode. I have been have no start problems lately also. I pulled to the shoulder and shut it down to reset the limp mode and of course it wouldn't start. It does it when it is at operating temp. I get it towed to the shop and put a battery charger on it to get the batteries back up where I was cranking to try and get it started. After it cooled down it starts right up.
I put the computer on it today and I have some code I would like for you guys to help me understand what would set them off.
The first one is (supercharger overboost condition)
The second one is(Injector control pressure too low-engine cranking)
I suspect that the injector code is probably an o-ring problem in the high pressure oil system causing the no start problem but which one(s).
I don't understand the supercharger overboost. I was under a heavy lowed pulling a hard hill when it happen but I wouldn't think that the computer would let it overboost.My coolant and transmission temp were not high. Could my EGT's have gotten high setting off this code? The truck is stock.
Thanks in advance for any help.
Old Oct 13, 2010 | 09:05 PM
cheezit's Avatar
cheezit
overboost means that you passed 30 psi of boost. stuck/sticking turbo would be suspect here.
the icp to low is infact a high pressure oil problem of some sort. you will need to air test the system with the ipr commanded to 100% duty cycle. to figure out what the sorce of the leak is.
Old Oct 14, 2010 | 04:34 AM
transamz9's Avatar
transamz9
Is there somewhere I can find the steps to do this?
Old Oct 14, 2010 | 05:33 AM
bismic's Avatar
bismic
I have the procedure described in my "No Start" thread (or have links to it) - it is near the top in the Tech Folder. If you do not see it there, I can post it agan.
What year model is your truck?
RacinNdrummin
2009 - 2014 F150
Jan 30, 2015 05:43 PM
rjp1965
Nov 3, 2011 03:28 PM
Texas450
6.4L Power Stroke Diesel
Nov 11, 2010 07:04 PM
sevenall
Jul 6, 2009 12:54 PM
bluestreak1979
1983 - 2012 Ranger & B-Series
Aug 21, 2006 08:48 PM
