E4OD w/2 gears
Old Oct 12, 2010 | 09:43 PM
maxtruck00's Avatar
maxtruck00
E4OD w/2 gears
I have a 1992 F350 with the E4OD. I'm only getting 2 and 4 gear. The wiring harness is plugged in, and two of the pins have power. Is there supposed to be more pins than two that have power going to them? and where is the fuse for the trans?
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Oct 13, 2010 | 08:47 AM
rla2005's Avatar
rla2005
This should help you out:
Courtesy of Ford Fuel Injection
Old Oct 13, 2010 | 09:05 AM
danr1's Avatar
danr1
Best place to start is the computer, run the KOEO self test and see if it or CM can tell you anything about the problem.
Old Oct 13, 2010 | 12:23 PM
LCAM-01XA's Avatar
LCAM-01XA
She's in limp-home mode, thee should be codes stored in the PCM, hook a scan tool up to it and read the codes and see what they will tell you...
maxtruck00
Dec 19, 2010 06:24 AM
maxtruck00
Oct 12, 2010 07:48 PM
JamesHajek
Feb 26, 2010 03:37 PM
Bumpkis
Dec 27, 2009 02:03 PM
7700
1997 - 2003 F150
Jul 19, 2009 08:10 AM
