Sponsored by: Kumho
reinstalling pitman arm
Old Oct 12, 2010 | 09:17 PM
SKS45's Avatar
SKS45
okay, so the new/rebuilt box is in, new lines, everything good to go. Old pitman arm starts on fine. How hard can I tap this thing without damaging the box. I'm still a good 1/4 inch away from it being on all the way. Any input would be appreciated.
thanks
Brett
Old Oct 13, 2010 | 05:05 AM
mistakenID's Avatar
mistakenID
Can't you finish pushing it into place when you tighten the nut?
Old Oct 13, 2010 | 06:52 AM
Lazy K's Avatar
Lazy K
What MID says X2. You should never have to hammer a pitman arm on.
Make sure that you have it on the right splines before you wind it up with the nut.
Old Oct 13, 2010 | 07:16 AM
SKS45's Avatar
SKS45
thanks guys. Right now I've got the drag link disconnected from it so when I put the wrench on the nut I end up turning the shaft, etc. I'll hook up the drag link which should help hold it in place. I've only tapped it on at this point so hopefully I haven't damaged anything internally. Remind me to tell the story about the 1/2 torque wrench that slapped me in the forehead when I tried to tighten the frame to steering box bolts to 150 ft/lbs instead of 55 ft/lbs. Yep, read the wrong torque settings chart. This has certainly been an adventure. Thanks again
Dezl Newbie
Dec 6, 2016 12:39 PM
Boomer89
Sep 26, 2016 06:33 PM
jerryst
Sep 18, 2016 04:56 PM
DemonRace6
Sep 13, 2011 01:19 PM
FireBlue
Mar 7, 2011 03:17 AM
