HPOP Seals and reinstall
Ok, I have been reading alot on here over the weekend. I am currently in the process of replace seals and what not. I have it wll out and cleaned. I have just finished up the fuel bowl bc while I had it out I just did it bc it was just under $25.
I am a little nervious about stating on the HPOP. I dont wnat to mess it up. This project probally has taken my a little longer then it should but I want to make sure I get it right. I have been going back n forth to the net checking and reading things.
Is there any were that there is a step for step with every thing that is needed to be done?
Another question I had is do I fill it back up with oil after I get it reinstalled? Were do I fill it if I do?
ANY AND ALL ADVICE WILL be greatly app!!
I have the 2001 SD books. Are you needing a step-by-step process for removal and replacement of the pump and reservoir or are you just needing the information on doing the o-rings, IPR and unserviceable plug? If it is the latter, Dieselorings.com has the write up in PDF form that covers pretty much everything.
dieselsubmariner
11-07-2014 07:37 AM
bc2sv
09-08-2009 07:39 PM
