Smog Pump
Old Nov 20, 2010 | 05:21 PM
jrwhitmire's Avatar
jrwhitmire
Take your old belt & cut it, route it around the pulleys with the tensioner held back, mark it where the cut end overlaps, & measure it. The 910 in your belt means 91". i used this method when I eliminated the smog pump on my 5.8, worked fine. You should be able to exchange your new belt, unless you've gotten it all greasy or something.
Old Nov 20, 2010 | 05:22 PM
jrwhitmire's Avatar
jrwhitmire
The 915 belt is 91 1/2" BTW.
Old Nov 20, 2010 | 11:28 PM
cjben's Avatar
cjben
Originally Posted by truknut1972
Well I bought the 4060915 belt that cjben suggested but its longer than my factory belt. 4060910 is the Gates #. I even called Summit they said they don't carry a SP elimator for the F150 only the mustangs. So what do I do now? Thanks.
I am not sure why it didn't work for you,maybe there is a difference between the belt routings of a 92 and a 95?
Old Nov 21, 2010 | 06:32 AM
Ton van der Sluijs's Avatar
Ton van der Sluijs
smog removed
Hi, y'all.
I've removed all the hoses from that smogrubbish , now the pump is still waiting for a place on the scrapheap... I do have a 5.8l efi... What is the size serpentinebelt exactly which I have to buy?
all the best Ton van der Sluijs
Old Nov 21, 2010 | 08:26 AM
jrwhitmire's Avatar
jrwhitmire
Originally Posted by Ton van der Sluijs
Hi, y'all.
My truck is at work so I can't answer you today, if nobody else does I'll post the size tomorrow for you. Mine's an '89 F250 5.8 with the dummy air conditioner pulley(no way to remove that, I tried) so you'd need to check if our trucks both called for the same size stock belt, or it'll be the wrong size. I imagine Ford made the dummy pulley the same size as the Air Conditioned trucks compressor pulley, but I'm not sure.
Old Nov 21, 2010 | 09:28 AM
Ton van der Sluijs
Hi there. Thanks a lot for your reply. Okay , I;m looking forward for your info.
Her's a pic of my truck.
all the best
Ton van der Sluijs
the Netherlands
Old Nov 21, 2010 | 06:07 PM
96ford250's Avatar
96ford250
mine is a 940k6 its tight but it will get on there chances are you will have to go to the auto parts store atleast twice i did
Old Nov 22, 2010 | 09:58 AM
jrwhitmire's Avatar
jrwhitmire
Dayco #5060830, I have a 3g alt on mine, I forgot 'till I looked under the hood, the pulley's a little bigger, but that size should be right or close, assuming all other pulleys are the same between our 2 trucks
Old Nov 22, 2010 | 12:25 PM
95 F150 Dude's Avatar
95 F150 Dude
Guys,
Not to hijack a thread here but are you guys passing emissions tests without the smog pump?
Scott
Old Nov 22, 2010 | 01:17 PM
Ton van der Sluijs
Hi; there;
Here in the Netherlands they don't test your smog; they test the CO2 value and the Lambavalue.
Because I'm using LPG (injection) Smogtests are useless because LPG is the cleanest fuel one can get.
All those smoghoses are now in the dustbin ; what a luxurious space to change the sparkplugs! I removed the coalcannister from the gastank as well. Let Al Gore keep an eye on the environment; I'll do my business
all the best Ton
Old Nov 22, 2010 | 02:10 PM
Fordfan95's Avatar
Fordfan95
87 5/8 belt works good
my truck is a 88 with a 302 with a gates 87 5/8 with the smog pump took off
flkeysff
Sep 11, 2013 03:00 PM
BearFootCustom
16
Jun 3, 2010 10:52 PM
1994 F250: 351, C6
15
Feb 16, 2009 02:25 PM
scottddove
Oct 8, 2005 10:00 PM
jaeki5
Jun 24, 2003 02:26 AM
