Sponsored by: Kumho
Always replace rotors with pads..?
Old Oct 11, 2010 | 08:17 AM
DaveTV's Avatar
DaveTV
Hi all - wondering if it is standard practice these days to always replace rotors when changing brake pads? I realize they are pretty cheap these days. I was inspecting my brakes yesterday and will be needing front pads and the rotors didn't look all that bad, but it seems cheap insurance to slap on some new rotors while its all apart..?
Old Oct 11, 2010 | 09:34 AM
Lazy K's Avatar
Lazy K
It would not be common practice to do so. However if the rotors are grooved, cracked or warped then they should be replaced.
Old Oct 11, 2010 | 10:10 AM
thomabb's Avatar
thomabb
If you are not going through at least 2-3 sets of pads per rotor, there is something wrong. Just make sure the rotors get turned at every pad change.
Old Oct 11, 2010 | 01:09 PM
DaveTV's Avatar
DaveTV
Thanks, but that's the thing: for the price of getting them "turned", it's easier and just as cheap to replace them, they don't cost much.
Old Oct 11, 2010 | 02:18 PM
thomabb's Avatar
thomabb
What are you driving? It costs $10 to $15 to turn down a rotor. Where are you getting rotors for that money?
Old Oct 11, 2010 | 02:27 PM
DaveTV's Avatar
DaveTV
I called 3 different local auto parts stores, they said they don't turn rotors at all, no one bothers doing it anymore because new rotors are so cheap these days, they have them for my Escape for like $31 apiece.
Old Oct 12, 2010 | 10:44 PM
85e150's Avatar
85e150
Price an OEM vs. the auto chain Chinese items.
You might as well buy the cheapie vs. the OEM with some, as some OEM rotors warp if you look at the wrong. But if your OEM rotors didn't warp, you may be in for a new experience with the cheapies.
I must say, I bought a cheapie for the back of my Explorer, and it seems to have worn ok and no warpage...unusual for rears to warp, so perhaps no surprise there.
Old Oct 13, 2010 | 06:33 AM
DaveTV's Avatar
DaveTV
Do shops even turn rotors anymore? I don't recall that being done when I had brake jobs doneon other vehicles in recent years, they just slapped new rotors on.
Old Oct 13, 2010 | 06:46 PM
Redneck1465's Avatar
Redneck1465
We turn rotors alot when they are the OEM rotors because they don't warp as bad as the aftermarket (Autozone) rotors. But the first thing we do is check to see how close the rotor is to its safety level because they can only be turned down so much before they are no longer considered safe.
Old Oct 15, 2010 | 10:38 AM
hcbph's Avatar
hcbph
Turning Rotors
If you have an O'Reily Auto Parts in your area, might check them out. I had the rotors on my 97 turned there last spring. Also maybe check your Yellow Pages, probably under Brake Parts or Repair.
Paul
cdestuck
2004 - 2008 F150
13
Apr 11, 2012 10:37 AM
nsaikia
2004 - 2008 F150
17
Dec 8, 2010 08:02 AM
kevin.ford-trucks
Apr 29, 2010 12:22 AM
wanderinginNY
Mar 16, 2009 05:19 AM
joners
Apr 20, 2008 09:44 PM
