EFI manifold sealing
Old Oct 10, 2010 | 09:57 PM
Kennewick's Avatar
Kennewick
I have a leak at the mani to down pipe connection. Is there no gasket there? I have tried to find a gasket or something........perhaps a little info please.
Old Oct 10, 2010 | 11:06 PM
ooCHICOoo's Avatar
ooCHICOoo
what truck you have ? you have the Y maniforld
Old Oct 11, 2010 | 01:26 AM
hgb4x4's Avatar
hgb4x4
there is no gasket there that I know of
Old Oct 11, 2010 | 01:37 AM
ooCHICOoo's Avatar
ooCHICOoo
its true sr noo gasket in that area ok
Old Oct 11, 2010 | 10:26 AM
Kennewick's Avatar
Kennewick
My sig says 88 4.9, EFI manifolds front and rear split with two exhaust flanges with 2 studs each.
Ok so now I've been told there isn't any gasket. Can anyone elaberate on fixes or just put in new pipe flanges.....I mean can the serfaces just be sanded or something? Not sure I can touque them any tighter. The PO for some reason had the wrong stud sizes installed and I couldn'r torque them down. I went to the junk yard and pulled some original studs and I can spot torque them...er (torque them till I see spots) but I still get that blasted exhaust tick.
Old Oct 11, 2010 | 11:13 AM
AbandonedBronco's Avatar
AbandonedBronco
The EFI manifolds seal up with pressure. The exhaust pipe is dished slightly smaller than the "ball" shaped end of the manifolds. When they torque, the dish presses onto the ball, sealing it. If it's not sealing, the exhaust pipe connections may have been stretched too much and no longer press onto the manifold tightly.
Secondly, are you sure it's that connection that's leaking and not the intake/exhaust gasket?
the5schlueters
Nov 12, 2013 12:12 PM
Xaviae
Jun 9, 2013 11:45 PM
bruno2
Jun 8, 2012 11:56 AM
Martys82
Apr 6, 2003 01:55 AM
Torque1st
Sep 8, 2002 12:57 PM
