Where would I find the Chassis number? duh
03-27-2017, 10:49 PM
Busted Knuckles
I was trying to order the rear rubber brake line and it's asking specifically;
Rear; 4WD; From Chassis # E24001
Or
Rear; 4WD; To Chassis # E24000
I searched and couldn't find it, it's probally simple but I'm stumped
o
Thanks
03-27-2017, 11:00 PM
That's early models and late models. What's the manufacture date of your truck? And what's the vin number end with?
03-27-2017, 11:13 PM
I take it you have a 69 model? This is the consecutive unit number of the vin. -E23999 was built Oct. 68, and E24000+ was built Nov. 68+.
03-27-2017, 11:33 PM
Busted Knuckles
Sorry bout the big pic
1969 F250 4X4 (F-260) 360, manual.
03-28-2017, 12:20 AM
Busted Knuckles
While I have the experts, my Dana 44 front differential has the numbers 44 6CF on the housing, is this a 3000 lb or 3500 lb unit? The steering knuckle housing ? (ball and socket) has 8 bolts.
03-28-2017, 01:02 AM
It is the light duty 44. You have a 6800 GVW. The 3500 HD has 12 bolts and was mostly used for crews.
03-28-2017, 01:08 AM
Busted Knuckles
Quote:
Originally Posted by
RichS2659
It is the light duty 44. The 3500 HD has 12 bolts and was required for crews.
thanks
03-28-2017, 01:19 AM
Busted Knuckles
RichS2659
So I'm a "Rear; 4WD; To Chassis # E24000" I guess.
Thanks a bunch, time to order some stuff
03-28-2017, 02:05 AM
Yes, yours is E13965 so under E24000
03-28-2017, 02:27 PM
You can find the VIN on the frame too. It's located just about inline with the battery (on the passenger side).
You can just make out the vin next to that ground wire on the frame
03-28-2017, 04:47 PM
roguewave
I was trying to order the rear rubber brake line for a
1969 F250 4WD and it's asking specifically:
Rear 4WD;
before serial number E24,001
Or
Rear; 4WD;
from serial number E24,00
Serial number is the last 6 digits of the VIN
C6TZ-2282-A .. Rear Brake Hose - 24 1/4" long / Obsolete ~
1 available NOS
1966 F250 2WD; 1967/68 F250 4WD; 1969 F250 4WD
before serial number E24,001.
This is the
correct hose as your serial number is
E13,965
This hose is
not correct.
C9TZ-2282-A .. Rear Brake Hose - 22 15/16" long / Obsolete ~
0 available NOS
1969 F250 4WD
from serial number E24,001; 1970/72 F250 4WD
03-28-2017, 10:41 PM
Busted Knuckles
You guys are the best
fisherman_chuck
08-03-2015 08:42 PM
dcrahn
11-20-2012 04:31 AM
shawn11762010
07-10-2012 07:38 PM
thefordlane
07-22-2010 09:44 AM
Blue Canoe
07-28-2009 10:45 PM
