Sponsored by: Halo Lifts
2017 F150 MPG vs Tire Size
Old 10-27-2016, 04:31 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow 2017 F150 MPG vs Tire Size
This question at this time...is pure speculation because the 2017 F150 with new revised 3.5L EB is not out right now. However, this is still a valid question...IMHO.
Truck in Mind:
2017 F150 Lariat 4x4 3.5L EB SuperCrew 6.5' bed 3.55 Max Tow
OEM Tire: 275/65R18 equates to a 32.1" tire
So...the question is: How many miles per gallon would I lose if I go with 33" or 35" (equivalent)??
Now...this is all based off the Suggested MPG that FORD claims at 18 city and 23 hwy
Thanks!
biz
Old 10-27-2016, 07:03 PM
djjoshuad's Avatar
djjoshuad
djjoshuad is offline
in order to fit 33" you're going to want to lift the front at least a little. To fit 35" you'll have to go up at least 2". The additional drag plus the heavier weight of the tire is going to contribute a lot more to fuel economy than tire size alone. In my case, a 2" lift and keeping the stock tires resulted in about a 2MPG loss on the highway. On my last truck, same suspension but with a 34" much heavier all-terrain tire, I lost about 3.5 MPG on the highway.
Old 10-27-2016, 09:30 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Yes...that is correct. I will be planning a ReadyLift 2.25" leveling kit install.
If I lose 3 mpg, that would be acceptable. Going from 23 to 20 is still awesome mileage...IMHO.
djjoshuad -- Thanks for your experience!
biz
Old 10-27-2016, 10:55 PM
djjoshuad's Avatar
djjoshuad
well I should clarify... my last truck was a Tundra, and it got about 18 MPG hwy in stock form. losing 3.5ish with the lift and tires means about 20% loss. If you translate that percentage to your truck, I would expect somewhere between 4.5 and 5 MPG loss. IMO, if you go up 2.5" and put on some 35" heavy tires, 18 MPG on the hwy would be quite good. I wouldn't be surprised if you hit more like 16, depending on your right foot
Old 10-28-2016, 12:56 AM
JKBrad's Avatar
JKBrad
JKBrad is offline
I went with a 2.25 ReadyLift. Tires spec at 34.3" tall. Before I corrected the speedometer, It looked like I lost 2-3 MPG on average. After speedometer correction my fuel economy is not too far from stock, within 1.5 MPG or so.
The tire I selected resulted in a 10-12% speedometer error, which had a negative impact on percieved MPG. Now the speedometer is correct, but with a 3-5% slow odometer error. This is consistent with the factory speedometer reading fast by the same amount. Now the dash readout for MPG and hand calculation are closer than it was with the factory tires and speedometer setting.
My biggest MPG loss is driving into headwinds at 75 MPH plus speeds. Also, I have notably better MPG at elevations over 4500' using medium grade gasoline. The EB loves climbing mountain roads, rarely down shifting lower than 5th.
Old 10-30-2016, 05:30 PM
biz4two's Avatar
biz4two
biz4two is offline
Thumbs up
That is some good positive news JKBrad. Thanks!
The '17 3.5 EB should perform brilliantly here in the ABQ area. We are about 1 mile above sea level (5280 ft) in elevation. Plus...most of the locations I drive in NM...just go UP from there.
Think I might have found my perfect combo in a '17 F150. Will look good, but also still perform.
biz
Old 10-30-2016, 06:54 PM
JKBrad's Avatar
JKBrad
JKBrad is offline
You won't believe the thrust you will feel when you give it just partial throttle on a long grade, even at high elevations. I drove it up to 9000' at Cloudcroft and could easily pass any slower moving traffic. And thats with tires 2.4" taller than stock.
Old 01-02-2017, 07:41 AM
Trail_Rider's Avatar
Trail_Rider
Trail_Rider is offline
My son just put 18" 33's on his from 18" 32.s and went from 21mpg to about 16. He's not a happy camper.
Old 01-02-2017, 09:39 PM
CuNmUdF250's Avatar
CuNmUdF250
CuNmUdF250 is offline
^^^^^ Looking cool comes with a price
Old 01-02-2017, 11:15 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
More info on the truck?? Year, engine, gearing, etc.
Did you son also program the ECM with a HyperTech for the new tire size? See post from JKBrad...
biz
Old 01-02-2017, 11:41 PM
Green Power's Avatar
Green Power
Green Power is offline
Your son is in the same situation I am. I went from 265/70/R17 to 275/70R18 and lost about 2.5-3 mpg. My solution is too find a nice looking set of 17'' wheels, and throw the 265/70/R17 on them.
Old 01-03-2017, 01:19 PM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
The width of those larger tires will kill your mileage worse than the diameter... Then there is rolling resistance to figure into the equation. You switch out highway treat for an all terrain tread - you pay yet another penalty...
Air your tires up to the maximum on the sidewall for the best fuel economy and load carrying capacity.
Lager diameter tires will mess with your overall gearing to a degree - but typically it will be lower RPMs on the highway and may well result in better fuel economy given the same footprint as the previous tires.
Old 01-03-2017, 03:00 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
That is interesting. However, are you sure you lost the 2.5-3 mpg? It really is impossible to tell if you did not re-calibrate the ECM. After all the miles driven will not be proper on the odometer because of the revolutions per mile difference from larger tires. Plus, the transmission will not be shifting at the proper times, because it still thinks the tire size is stock...which could result in poor mpg.
Just a few thoughts here...
biz
Old 01-04-2017, 03:19 PM
Espo4442's Avatar
Espo4442
Espo4442 is offline
I'll be interested in seeing what a 17' 3.5 ecoboost does with a set of 35's.
Mdennis0_8
35
02-23-2024 07:13 PM
sy628109
6.7L Power Stroke Diesel
09-01-2011 06:16 PM
renopat
2009 - 2014 F150
03-29-2011 07:31 PM
xnavyflyer
2004 - 2008 F150
07-05-2007 05:05 PM
hank89
04-04-2007 08:52 AM
Quick Reply: 2017 F150 MPG vs Tire Size
