Howling noise
Howling noise
2005 F250 195k miles. The truck has developed a howling noise comeing from what sounds like the driveline. It is most apperant at slow speeds with the windows up. It almost sounds like tire growling on the pavment but I can also hear it driving through the grass.
The last vehichle that i heard this from was my dd and ended up being a pinion bearing.
I put it on jack stands, removed the tires axles and driveshaft, spun the pinion yoke by hand it feels smooth. I also checked the rear hub bearings and they feel fine also. With the axles out and it up on jack stands i ran the truck and could still hear the noise. It almost sounds like it is comeing out of the T case output. The T case is a NP 271(manual shift).
Any ideas??
Thanks guys.
Any ideas??
Thanks guys.
i had this very sound myself, people kept telling me it was the tires. Well low and behold i got the front end jacked up and spun the front passenger wheel and there it was. Truck has 117k miles on it.
what i noticed was it would kinda stop when i turned left on city streets at low speed. if i turned right it would come back slightly. for your sake i hope its not the rear end.
Oddly thats the only one i didn't check, pass side front.
Ill be checking that this week.
Thanks everyone for your input.
had fail was not at 90º to the shaft centerline.
However the hub bearing could be a better place to start.
Sean <BR>
6.0L Tech Folder
