Which exhaust system do you guys run?
Old 09-21-2016, 11:07 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
I currently have a MBRP 4" turbo back aluminized metal that apparently around 5 years in the salt is all it can take. Was under the truck last night and noticed quite a few holes that I never saw before. So there are Diamond eye, or MBRP. Which do you guys have? Pros and Cons? T304 OT T409 stainless?
Old 09-22-2016, 08:04 AM
ExPACamper's Avatar
ExPACamper
ExPACamper is offline
I have the MBRP 4" turbo back T409 Stainless Steel with T304 tip.
The underneath components get a patina fairly quickly, but people normally only see the T304 tip.
I like it a lot, still quite solid. I couldn't justify a bunch of extra $$ for hidden T304.
As you surely know, there is only "one way" to get it to fit around the tank in the Excursion. It has to be lifted, turned, and supported "just right" to clear everything and not rub.
The sound is still quite tame INSIDE the passenger area, but if I open the rear window, you can hear the turbo whistle quite nicely! Has a deep, mean sound from outside.
Not at all terrible on long trips, either.
You probably know all this, except for the materials. They have held up quite nicely on our daily driver Excursion here in the rust belt
Old 09-22-2016, 08:28 AM
Firefighter 1406
How long has it been installed on your truck? I run with a muffler delete currently. I am thinking about this system with a muffler again. Gets a little much when towing for long distances. I don't know. Maybe I am getting old. But I do love the whistle, probably will loose that with the muffler.
Old 09-22-2016, 09:05 AM
ExPACamper's Avatar
ExPACamper
I've been running this for about a year and a half. It's an Excursion, which is a little more $$ and I'm told better for soundproofing the cabin, so maybe that's related to your sound?
I don't have a muffler or cat. Exempt.
With the windows closed, I can only get a hint of whistle through the firewall, nothing from the exhaust.
Had a nice throaty sounding muffler on my 4Runner, but the DRONE at cruising speed was terrible!
I don't notice it on this one. Maybe it's failing on yours, or is it touching something it shouldn't? All rubber hangers?
Old 09-22-2016, 12:21 PM
HKusp's Avatar
HKusp
HKusp is offline
4" Stainless steel Flow-Pro exhaust by Thoroughbred Diesel. I have the delete and a muffler. I can switch between the 2 depending on what I am doing. Been running the muffler for several moths, haven't done any towing above 7,000lbs so didn't really need to go with the delete section. Very high quality and probably one of the easiest kits I have ever put on any vehicle. The hardest part was lining up the down-pipe. It took less than an hour to do, start to finish. Here a few bad pictures of it.
Size:  158.9 KBThat one is the delete section.
Size:  141.9 KB These clamps make it super easy and way better than the old style "U" clamps.
Flo Pro Exhaust for 99-03 Ford Powerstroke
Old 09-22-2016, 03:05 PM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
Magnaflow SS here and very happy. No fitment issues at all and no drone. Also came with all of the parts/pipe to accomodate different body configurations ( long/short bed Ex cab or 4 door ) if necessary.
Old 09-22-2016, 03:06 PM
ExPACamper's Avatar
ExPACamper
Tell me more about these clamps!
Can they do uneven sizes, like 3" to 2.5"
I am working on a different Ford exhaust right now (460 gas). Thanks!
Old 09-22-2016, 04:17 PM
HKusp's Avatar
HKusp
HKusp is offline
They may make them but I haven't seen them. I would call Thoroughbred and see. It seems like something that should be done.
Old 09-22-2016, 04:18 PM
camocrewcab's Avatar
camocrewcab
camocrewcab is offline
Same here Magnaflow SS, no problems and no drone.
Old 09-22-2016, 05:26 PM
UcaN's Avatar
UcaN
UcaN is offline
Those are what is called a Band Clamp. They are sold in various sizes, and you can find them at all Big Rig truck parts stores.....
Old 09-22-2016, 09:17 PM
schlepprock250's Avatar
schlepprock250
schlepprock250 is offline
4"turbo back stainless MagnaFlow here. Perfect fit and good sound. I have the muffler on, getting old I guess.
Old 09-23-2016, 07:37 AM
Firefighter 1406
Manga flow seems to be winning out right now. Now if it only was like $300 instead of $499
Old 09-23-2016, 08:01 AM
ExPACamper's Avatar
ExPACamper
Oh, are we voting? I already voted and I'm in PA. That means I can't vote TWICE like some states, but I can have my DEAD relatives vote
But seriously, I'm happy with my MBRP. Sounds like others are happy with what they are running, too. That's a good thing
My suggestion is to go TRY a few. See if any members or buddies are near you with exhausts you are considering. Videos are nice, but they often have quite DIFFERENT frequencies reproduced or picked up. In-cab experience and highway speeds can be quite varied.
If you have the chance, invite a member to lunch
Old 09-23-2016, 08:07 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
4" SS of some sort with muffler came with truck and can't tell you much about it.
Those clamps have been in use on heavy trucks for years and they are a dream to work with but I have seem many of them with soot stains around them, I do not know what you can do to seal them up.
Old 09-23-2016, 08:22 AM
Sous's Avatar
Sous
Sous is offline
Received 4,464 Likes on 2,853 Posts
I run the 4" MBRP with the muffler and it is a good system. I guess you already know from your experience though that it is a southern states type of system. I like the deep sound it gives the exhaust and the virtually zero drone noise because of the muffler.
It was a real pain in the *** to install the downpipe though, not really sure why, but it was a nightmare.
Quick Reply: Which exhaust system do you guys run?
