Anyone have a Recon LED 3rd brake light??
I just purchased a Recon 3rd brake light online and was told it fit 1997-2003 Ford F-150, 2000-2004 Ford Excursion. Well I had a 2001 excursion, so I figured it would fit. I bought it used. I did a little research and found the part number he had listed (264122BK) was the same as was stated online from other vendors that it fit these years. Could the guy have put the wrong part number on his ad?
Any help??
Any help??
I know most aftermarket parts dont fit as good as OEM, but this thing fits terrible, you would think that is didnt go to the Ex. It looks that bad. Maybe I wont get any responses, but i thought I would try.
I'm no expert BUT I'm pretty sure the Excursion third brake light is actually a unique design exclusive to the Ex. The regular Superduty ones may kinda fit but not really correctly. Sounds like what you have described. Looking around on the web I have seen several listings for taillights that are advertised as fitting both the F series trucks and our Excursions........the only problem with that is we share taillights with the Econolines NOT the Superdutys. I have seen a photo of the Ford Lightning third brake light/cargo light mounted on an Ex liftgate and the fit was very poor. You should be able to sell the Recon unit to a Superduty guy, Good luck.
Tom
Tom
The first is the Recon aftermarket one
03-07 FORD EXCURSION SMOKE RECON SIDE MIRROR LED LIGHTS: eBay Motors (item 230364173683 end time Oct-28-10 15:22:55 PDT)
The second has to be replaced.
I don't believe its fits, Does anyone know?
Tom
Tom
I cant use the courtesy light either, but I am hooking it up to my LED flasher. I will post a video of it when Im done. It will quad flash the courtesy light then quad flash the brake light.
here is link hope it works this is a picture with the led tailight and the third brake light i can try tomorrow to get closer pics but now it is dark out lemme know.
https://www.ford-trucks.com/forums/p...ictureid=42664
https://www.ford-trucks.com/forums/p...ictureid=47905
here is link to pic from my phone best i can do hope it helps
