Anyone have a Recon LED 3rd brake light??
I just purchased a Recon 3rd brake light online and was told it fit 1997-2003 Ford F-150, 2000-2004 Ford Excursion. Well I had a 2001 excursion, so I figured it would fit. I bought it used. I did a little research and found the part number he had listed (264122BK) was the same as was stated online from other vendors that it fit these years. Could the guy have put the wrong part number on his ad?
Any help?? |
RECON parts are not a highly talked about subject here, as I've asked acouple of questions about using RECON lights and not really getting a enough information about why I couldn't install they're lights. Good luck.
Originally Posted by hwybee22
(Post 9405301)
I know most aftermarket parts dont fit as good as OEM, but this thing fits terrible, you would think that is didnt go to the Ex. It looks that bad. Maybe I wont get any responses, but i thought I would try. |
I'm no expert BUT I'm pretty sure the Excursion third brake light is actually a unique design exclusive to the Ex. The regular Superduty ones may kinda fit but not really correctly. Sounds like what you have described. Looking around on the web I have seen several listings for taillights that are advertised as fitting both the F series trucks and our Excursions:confused:........the only problem with that is we share taillights with the Econolines NOT the Superdutys. I have seen a photo of the Ford Lightning third brake light/cargo light mounted on an Ex liftgate and the fit was very poor.:eek: You should be able to sell the Recon unit to a Superduty guy, Good luck.
Tom |
I wanted to get RECON lights all the way around and also get the strobe light kit, but was shot down by RECON when they said that the lights wouldn't fix my X. Oh well.
http://img.auctiva.com/imgdata/6/9/5...5334022_tp.jpghttp://www.dsfs.com/photos//1309/1/3...65999_0026.jpg The first is the Recon aftermarket one 03-07 FORD EXCURSION SMOKE RECON SIDE MIRROR LED LIGHTS: eBay Motors (item 230364173683 end time Oct-28-10 15:22:55 PDT) The second has to be replaced. I don't believe its fits, Does anyone know? |
Tio, they should fit. All of the Superduties and the Excursions used the same mirror (with signal) for the years listed in the auction.
Originally Posted by WE3ZS
(Post 9405417)
Tom |
i have a recon led third brake light works good and fit good no problems 2000 ex i cant us the courtesy light part but brake light part is good.
Originally Posted by az2ny2008
(Post 9405687)
I cant use the courtesy light either, but I am hooking it up to my LED flasher. I will post a video of it when Im done. It will quad flash the courtesy light then quad flash the brake light. |
here is link hope it works this is a picture with the led tailight and the third brake light i can try tomorrow to get closer pics but now it is dark out lemme know.
https://www.ford-trucks.com/forums/p...ictureid=42664 |
(Post 9406069)
yeah mine has small gap but it is watertight but the screws put it tight its definately not real snug like stock but all aftermarket parts like that.
azny2008 can you get a closer pic of your 3rd brake light? looks good.
https://www.ford-trucks.com/forums/p...ictureid=47905
here is link to pic from my phone best i can do hope it helps |
