Engine Specifications for 80-86 Trucks
Old 10-01-2010, 09:15 AM
smashclash's Avatar
smashclash
smashclash is offline
Got this off wikipedia. I'm really surprised with the EFI 302's specs. Other than the carb vs. EFI is there anything else that was done to these to get them to have so much more horsepower than their carbed sisters? I mean for the 302 to have 35 more HP and 10 less ft/lb torque than a 351 carbed is quite a site. Ford F-Series - Wikipedia, the free encyclopedia
<table class="wikitable"><tbody><tr><th>Engine</th> <th>Years</th> <th>Power</th> <th>Torque</th> <th>Notes</th> </tr> <tr> <td>232 CID Essex V6</td> <td>1982–83</td> <td>110 hp (82 kW)</td> <td>183 lb·ft (248 N·m)</td> <td>
</td> </tr> <tr> <td>255 CID Windsor V8</td> <td>1980–81</td> <td>115 hp (86 kW)</td> <td>206 lb·ft (279 N·m)</td> <td>2bbl</td> </tr> <tr> <td>300 CID Straight-6</td> <td>1980</td> <td>117 hp (87 kW)</td> <td>227 lb·ft (308 N·m)</td> <td>1bbl</td> </tr> <tr> <td>300 CID† Straight-6</td> <td>1980</td> <td>120 hp (89 kW)</td> <td>229 lb·ft (310 N·m)</td> <td>1bbl</td> </tr> <tr> <td>300 CID Straight-6</td> <td>1981–86</td> <td>122 hp (91 kW)</td> <td>255 lb·ft (346 N·m)</td> <td>1bbl</td> </tr> <tr> <td>302 CID Windsor V8</td> <td>1980–85</td> <td>133 hp (99 kW)</td> <td>233 lb·ft (316 N·m)</td> <td>2bbl</td> </tr> <tr> <td>302 CID Windsor V8</td> <td>1985–86</td> <td>185 hp (138 kW)</td> <td>270 lb·ft (366 N·m)</td> <td>EFI</td> </tr> <tr> <td>351 CID 351M V8</td> <td>1980–82</td> <td>136 hp (101 kW)</td> <td>262 lb·ft (355 N·m)</td> <td>2bbl</td> </tr> <tr> <td>351 CID Windsor V8</td> <td>1980–82</td> <td>136 hp (101 kW)</td> <td>262 lb·ft (355 N·m)</td> <td>2bbl</td> </tr> <tr> <td>351 CID Windsor V8</td> <td>1983–85</td> <td>150 hp (110 kW)</td> <td>280 lb·ft (380 N·m)</td> <td>2bbl</td> </tr> <tr> <td>351 CID HO Windsor V8</td> <td>1984–86</td> <td>210 hp (160 kW)</td> <td>305 lb·ft (414 N·m)</td> <td>4bbl</td> </tr> <tr> <td>400 CID† 400 V8</td> <td>1980–82</td> <td>136 hp (101 kW)</td> <td>310 lb·ft (420 N·m)</td> <td>2bbl</td> </tr> <tr> <td>420 CID Navistar diesel V8†</td> <td>1983–86</td> <td>170 hp (130 kW)</td> <td>315 lb·ft (427 N·m)</td> <td>IDI</td> </tr> <tr> <td>460 CID† 385 V8</td> <td>1983–84</td> <td>225 hp (168 kW)</td> <td>380 lb·ft (515 N·m)</td> <td>4bbl</td> </tr> <tr> <td>460 CID† 385 V8</td> <td>1985–86</td> <td>245 hp (183 kW)</td> <td>385 lb·ft (522 N·m)</td> <td>4bbl</td> <td>
</td></tr></tbody></table>
Old 10-01-2010, 11:54 PM
truckerboy's Avatar
truckerboy
truckerboy is offline
It is very interesting that the EFI 302 is so close to the 351 2bbl. There is probably a camshaft difference there ontop if that EFI.
Also, I find it interesting that the 460 4bbl actually made more torque than the 6.9 IDI. Guess that is what the 385 is there for.
6inarowmakeitgo
32
05-05-2022 09:56 PM
ridinginstyle
09-21-2015 03:06 AM
Stewart_H
12-04-2010 07:02 AM
morrisjl2
General Diesel Discussion
04-30-2009 03:00 PM
Nyborg
08-07-2008 12:28 PM
Quick Reply: Engine Specifications for 80-86 Trucks
