Various torque specs from A/C manifold to Valve cover bolts
Pete and I were talking about the torque specs for the pedestal and I told him I'd look it up. I figured I might as well just post this up for future reference and searches for anyone needing specs on something specific.
Various torque specs for the 7.3L PSD engine assembly.
I pulled this up for my 2002 truck but I'm sure they're fairly consistent for other model year 7.3's.
Torque Specifications
<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TH vAlign=bottom align=middle>Description</TH><TH vAlign=bottom align=middle>Nm</TH><TH vAlign=bottom align=middle>lb-ft</TH><TH vAlign=bottom align=middle>lb-in</TH></TR><TR><TD vAlign=top align=left>A/C manifold and tube retaining bolt</TD><TD vAlign=top align=middle>20</TD><TD vAlign=top align=middle>15</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Air brake ABS module bracket assembly mounting nuts</TD><TD vAlign=top align=middle>20</TD><TD vAlign=top align=middle>15</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Air cleaner housing mounting bolts</TD><TD vAlign=top align=middle>30</TD><TD vAlign=top align=middle>22</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Air cleaner support bracket mounting nuts</TD><TD vAlign=top align=middle>28</TD><TD vAlign=top align=middle>21</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Air compressor bracket mounting bolts</TD><TD vAlign=top align=middle>78</TD><TD vAlign=top align=middle>58</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Air compressor mounting bolts</TD><TD vAlign=top align=middle>68</TD><TD vAlign=top align=middle>50</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Air compressor mounting nuts</TD><TD vAlign=top align=middle>78</TD><TD vAlign=top align=middle>58</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Belt tensioner mounting bolt</TD><TD vAlign=top align=middle>43</TD><TD vAlign=top align=middle>32</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Camshaft position (CMP) sensor mounting bolt</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Camshaft thrust plate retaining bolts</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Connecting rod cap nuts</TD><TD vAlign=top align=middle><SUP>a</SUP></TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Cooling fan</TD><TD vAlign=top align=middle>101</TD><TD vAlign=top align=middle>74</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Crankshaft rear oil seal retaining bolts</TD><TD vAlign=top align=middle>20</TD><TD vAlign=top align=middle>15</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Crankshaft vibration dampener bolt</TD><TD vAlign=top align=middle>258</TD><TD vAlign=top align=middle>212</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Cylinder head bolt</TD><TD vAlign=top align=middle><SUP>a</SUP> </TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Drive gear access cover retaining bolts</TD><TD vAlign=top align=middle>27</TD><TD vAlign=top align=middle>20</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Engine front cover bolts</TD><TD vAlign=top align=middle>20</TD><TD vAlign=top align=middle>15</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Engine rear cover bolts</TD><TD vAlign=top align=middle>20</TD><TD vAlign=top align=middle>15</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Exhaust bracket to engine support bracket mounting bolts</TD><TD vAlign=top align=middle>50</TD><TD vAlign=top align=middle>37</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Exhaust manifold mounting pipe nuts and bolts</TD><TD vAlign=top align=middle>61</TD><TD vAlign=top align=middle>45</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Engine support bracket mounting bolts</TD><TD vAlign=top align=middle>103</TD><TD vAlign=top align=middle>76</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Front stabilizer bar mounting nuts</TD><TD vAlign=top align=middle>133</TD><TD vAlign=top align=middle>98</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Front support bracket to engine mounting bolts</TD><TD vAlign=top align=middle>103</TD><TD vAlign=top align=middle>76</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Front support bracket to number two crossmember mounting nuts</TD><TD vAlign=top align=middle>225</TD><TD vAlign=top align=middle>166</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Fuel return hose</TD><TD vAlign=top align=middle>26</TD><TD vAlign=top align=middle>19</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Fuel supply hose</TD><TD vAlign=top align=middle>50</TD><TD vAlign=top align=middle>37</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Flexplate mounting bolt
(automatic transmission)</TD><TD vAlign=top align=middle>121</TD><TD vAlign=top align=middle>89</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Flywheel mounting bolt
(manual transmission)</TD><TD vAlign=top align=middle>121</TD><TD vAlign=top align=middle>89</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Flywheel housing mounting bolts</TD><TD vAlign=top align=middle>20</TD><TD vAlign=top align=middle>15</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Generator and A/C compressor mounting bracket mounting bolts</TD><TD vAlign=top align=middle>49</TD><TD vAlign=top align=middle>36</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>High-pressure oil line connector (cylinder head)</TD><TD vAlign=top align=middle>26</TD><TD vAlign=top align=middle>19</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>High-pressure oil pump drive gear mounting bolt</TD><TD vAlign=top align=middle>129</TD><TD vAlign=top align=middle>95</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>High-pressure oil pump mounting bolts</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>High-pressure oil pump reservoir mounting bolts</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Idler pulley mounting bolt</TD><TD vAlign=top align=middle>55</TD><TD vAlign=top align=middle>41</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Intake manifold cover mounting bolts</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Main bearing cap bolts</TD><TD vAlign=top align=middle><SUP>a</SUP></TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Muffler assembly mounting nuts</TD><TD vAlign=top align=middle>50</TD><TD vAlign=top align=middle>37</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Number two crossmember mounting bolts</TD><TD vAlign=top align=middle>90</TD><TD vAlign=top align=middle>66</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Oil cooler retaining bolts</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Oil level indicator tube adapter nut</TD><TD vAlign=top align=middle>33</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Oil pan mounting bolts</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Oil pump body plate bolts</TD><TD vAlign=top align=middle>20</TD><TD vAlign=top align=middle>15</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Oil pump screen cover and tube flange bolts</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Oil pump screen cover and tube retaining nut</TD><TD vAlign=top align=middle>52</TD><TD vAlign=top align=middle>38</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Parking brake cable bracket mounting bolt
(automatic transmission)</TD><TD vAlign=top align=middle>28</TD><TD vAlign=top align=middle>21</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Parking brake cable clamp mounting bolts
(manual transmission)</TD><TD vAlign=top align=middle>28</TD><TD vAlign=top align=middle>21</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Power steering pressure hose</TD><TD vAlign=top align=middle>33</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Power steering pump mounting nuts</TD><TD vAlign=top align=middle>55</TD><TD vAlign=top align=middle>41</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Rear bracket to frame mounting nuts</TD><TD vAlign=top align=middle>250</TD><TD vAlign=top align=middle>184</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Rear support cap mounting nuts</TD><TD vAlign=top align=middle>144</TD><TD vAlign=top align=middle>106</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Rocker arm pedestal attaching bolts</TD><TD vAlign=top align=middle>27</TD><TD vAlign=top align=middle>20</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Slave cylinder lock nut</TD><TD vAlign=top align=middle>33</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Slave cylinder interlock bracket mounting bolts</TD><TD vAlign=top align=middle>59</TD><TD vAlign=top align=middle>44</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Starter motor mounting bolts</TD><TD vAlign=top align=middle>25</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Transmission oil cooler hoses</TD><TD vAlign=top align=middle>28</TD><TD vAlign=top align=middle>21</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Transmission shift lever housing mounting bolts</TD><TD vAlign=top align=middle>54</TD><TD vAlign=top align=middle>40</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Turbocharger exhaust inlet pipe-to-exhaust manifold bolts</TD><TD vAlign=top align=middle>28</TD><TD vAlign=top align=middle>21</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Turbocharger mounting bolts</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Turbocharger pedestal assembly mounting bolts</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Valve cover retaining bolts and nuts</TD><TD vAlign=top align=middle>11</TD><TD vAlign=top align=middle>8</TD><TD vAlign=top align=middle>—</TD></TR></TBODY></TABLE>
Stewart
search terms: torque spec specs specification specifications inch pound pounds lbs nut nuts bolt bolts wrench
Stewart
Macrobb
31
09-24-2020 08:00 AM
SuperDutyScaler
1999 to 2016 Super Duty
28
03-14-2018 07:39 PM
fastman35
13
11-27-2016 09:24 PM
Mitch1407
01-19-2011 11:31 AM
