Lighting Issues
Lighting Issues
So the only thing stopping me from getting my 77 F-250 on the road is that my brake lights and turn signals won't work. I changed the two cylindrical fuses under the dash and still no avail. Does that rectangular fuse under the dash control the lighting? I'm hoping its not a wiring issue. I know the bulbs are good and the emergency flashers work. Do the turn signals and brake lights use the same wires as the emergency flashers? Any troubleshooting help is greatly appreciated.
Steve
Steve
Turn signals and brake lights use the same wiring. You need to check and see if you have power at the brake light switch. If you do I would suspect the turn signal switch, the brake lights are routed through the turn signal switch.
The hazards are before the brake lights so its not uncommon to have the hazards work but not the brake lights.
check the ground tabs IN the plugs where the bulbs sit. they corrode and brake off a lot. I had no lights in the back of my truck, save for 1 parking side running light.
do your running lights work? they are the same bulb (different filament) as the brakes/signals
turn signal switch is right where you think - the column. the flasher switch sends signal right through the brake wire so it works with the ignition off.
Smithdad
08-17-2013 04:38 AM
Old_Ford_Man
01-07-2011 09:00 PM
dakonthemountain
13
11-26-2005 10:13 AM
Knight70F250
03-21-2005 11:42 AM
