how to remove harmonic balancer
Old 09-18-2010, 04:40 PM
kingford72's Avatar
kingford72
kingford72 is offline
how do you remove the harmonic balancer. 99 explorer with 5.0 liter v8. got the crank bolt out but theres no holes for my puller.
Old 09-18-2010, 05:28 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
WAG, is it possible you use the type with the arms that grab behind whatever you are pulling? That makes no sense for a harmonic balancer, but it wouldn't be the first time something didn't make sense.
Like this one, and note it says in applications: "...Ford 1995 and later V8...."
OTC 6667 Harmonic Balancer Puller
Old 09-18-2010, 05:33 PM
kingford72's Avatar
kingford72
thats what I was thinking but half way around the balancer it is cut out its not at the same level if you understand what I mean
Old 09-18-2010, 05:44 PM
kingford72's Avatar
kingford72
either there are no holes in this one ore they are completely camo over with dried grease but this one on ebay has holes 96 97 98 99 00 FORD EXPLORER HARMONIC BALANCER: eBay Motors (item 170537356279 end time Oct-07-10 10:30:38 PDT)
Old 09-18-2010, 05:51 PM
85e150's Avatar
85e150
Yea, that would make it pull off to one side.
Could you put a piece of metal behind it to pull on so the puller was even?
Not a lot of room to fool with it down there I know.
Maybe you'll get a better idea from another post.
Old 09-18-2010, 05:53 PM
85e150's Avatar
85e150
Is that what yours looks like, with that tone ring sprocket looking deal? You may have to dig for those holes.....
Old 09-18-2010, 06:03 PM
kingford72's Avatar
kingford72
that exactly what mine looks like what I need are the 3 holes in the front view
Old 09-19-2010, 08:43 PM
kingford72's Avatar
kingford72
got the balancer off, dried grease covered the holes and couldn't see them, poked around with a pick and it pushed right through. Can't believe how much stuff builds up inside the bottom pulley over the years.
Old 09-19-2010, 09:30 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Especially with oil leaks and never being cleaned. A pressure washer would probably have come in handy before starting that job.
genn
1983 - 2012 Ranger & B-Series
10-29-2014 08:37 PM
jack odom
08-17-2013 12:21 AM
IDI guy
15
07-07-2013 09:09 PM
Fredster
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
12-01-2006 07:22 PM
urif250
05-31-2002 08:15 AM
Quick Reply: how to remove harmonic balancer
