1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2004 Navigator Dash Lights
Old 09-08-2010, 12:39 PM
dohcfox's Avatar
dohcfox
dohcfox is offline
So what will cause all of the center stack lights on my Navigator to up and quit. The PRND2L lights are out, the head light switch light is out, the overhead AC/wing windows/rear door lights are out, door lock lights are out. Everything works fine, just can't see the buttons at night. Is there a light control module, are they fiber optic type lights with a central bulb?I have checked everyfuse that I looked like it might have something to do with dash lights. The instrument cluster and dome lights are perfectly fine, just the rest of the switch lights.TIA
Old 10-08-2010, 11:17 AM
dohcfox's Avatar
dohcfox
dohcfox is offline
Got a wiring diagram and the only thing I can see is that main power feed for the headlight and dimmer switches come from the underhood power box. I am guessing that either the headlight or dimmer switch has lost its ability to power the LEDs that light of the switch and button lights.
ANy ideas? Wonder how hard it is to crack open the switches.
Old 10-08-2010, 05:05 PM
alloro's Avatar
alloro
alloro is online now
Received 4,197 Likes on 2,433 Posts
The dimmer switch went bad, or someone turned it far enough to turn all the lamps off perhaps?
Old 10-18-2010, 04:11 PM
nutherford's Avatar
nutherford
nutherford is offline
I'm having a similar issue with my "03 Nav. Hey Alloro - glad to see you on this thread. You'll remember I just got over the fuel pump and wiring issue. I'm having a hard time convincing myself the shop didn't mess something up as they were poking around trying to figure out why the fuel pump had no power. They want to sell me an entire new instrument panel. No thanks, I'll do a little checking first.
dohcfox - I'm hunting around for info on this. I'll come back if I find anything.
Old 01-19-2016, 10:04 PM
Starry Night's Avatar
Starry Night
Starry Night is offline
I have the same issue with my 2004 Licoln Navigator. The backlights are out. Anyone ever find the answer to this issue?
jerrysrios
Electrical Systems/Wiring
87
01-21-2024 07:33 AM
firemarshalmike
07-07-2017 05:52 PM
superv10
05-22-2017 03:23 PM
Stanislaw
17
02-10-2017 12:01 AM
Ex-Jermin
10-28-2016 01:08 PM
Quick Reply: 2004 Navigator Dash Lights
