Need some wiring help
hey guys, I bought the Big Rig Running light kit w/ White LED courtesy lights for my E'99 F350 and so far I was able to hook them up to my parking lamps but I dont know where to hook them up to my Dome light.....I tried to use the door jam switch (inside the door) but I couldnt get power out of the wires.....shouldn't there be a power wire? is so which one? Is there a wire under the dash that I could connect to? (this would be my easist option) Thanks for the help.
Posted a PDF of the Courtesy Light Wiring Diagram in my photo album: https://www.ford-trucks.com/forums/p...ictureid=45863
Edit: That worked about as well as finding the wire by peeing on it to see if it's hot.
The diagram says there should be a Blue/Black wire running to the Door Courtesy Lamps on both sides that should be hot when the Interior Lamp Relay is activated.
The diagram also says you should have an Orange/Lt Green wire feeding the Dome Light through the GEM that's always hot.
amer28
1983 - 2012 Ranger & B-Series
03-03-2012 07:58 AM
AndeyHall
Electrical Systems/Wiring
21
10-16-2010 02:07 PM
