Need some wiring help
Old Sep 12, 2010 | 10:34 AM
jbounds's Avatar
jbounds
hey guys, I bought the Big Rig Running light kit w/ White LED courtesy lights for my E'99 F350 and so far I was able to hook them up to my parking lamps but I dont know where to hook them up to my Dome light.....I tried to use the door jam switch (inside the door) but I couldnt get power out of the wires.....shouldn't there be a power wire? is so which one? Is there a wire under the dash that I could connect to? (this would be my easist option) Thanks for the help.
Old Sep 12, 2010 | 05:12 PM
jbounds's Avatar
jbounds
*bump* Any body know?
Old Sep 12, 2010 | 06:36 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Jim (megawatt) should be able to help you with this one. He's the resident electrical guru.
Old Sep 12, 2010 | 07:49 PM
Mr. Finch's Avatar
Mr. Finch
are you just looking for a signal wire, or do you need something that can carry the extra load of the lights?
Old Sep 12, 2010 | 07:54 PM
StillNotKing's Avatar
StillNotKing
Posted a PDF of the Courtesy Light Wiring Diagram in my photo album: https://www.ford-trucks.com/forums/p...ictureid=45863
Edit: That worked about as well as finding the wire by peeing on it to see if it's hot.
The diagram says there should be a Blue/Black wire running to the Door Courtesy Lamps on both sides that should be hot when the Interior Lamp Relay is activated.
The diagram also says you should have an Orange/Lt Green wire feeding the Dome Light through the GEM that's always hot.
Old Sep 12, 2010 | 07:57 PM
jbounds's Avatar
jbounds
Im looking for a wire that will make the lights come on when I open up the door so I believe it has to be 12V to power the lights but only come on when the door opens and/or when the dome light is activated
Old Sep 12, 2010 | 08:56 PM
dn29626's Avatar
dn29626
Are you/Did you connect the lights through relay(s) ?
Old Sep 12, 2010 | 09:02 PM
SpringerPop's Avatar
SpringerPop
Those black/lt blue wires in the kick panels should be the ones.
Relays aren't needed, as these wires are fed by a relay already. It is fed by Fuse #14 in the under-dash fuse panel.
They are used for the running board lights on the Excursions.
Pop
Myfreeford
Electrical Systems/Wiring
Jun 2, 2023 01:04 PM
amer28
1983 - 2012 Ranger & B-Series
Mar 3, 2012 07:58 AM
AndeyHall
21
Oct 16, 2010 02:07 PM
552drpost
Aerostar
Mar 15, 2010 11:31 PM
TheBigBee
Mar 2, 2009 08:05 AM
